Here's how it looks out of the bag
Trim off the small 'lips' on the 'pegs' so it sit flush with the underside of the car
Cut off the 2 centre sections, these sit behind the number plate so arn't seen anyway
Centre the splitter in place and hold with gaffer tape
Drill 2 6mm holes to fix the corners of the centre section down neatly
This is what they look like when they're riveted in place. The rivets are strong and I used 5 on each side. I used the original turbo splitter holes where I could and drilled a couple of extras.
Halfrauds 6mm plastic closed end rivets did the job well
Underside
I trimmed the ends (using strong scissors!) flush with the wheel arch
JOB DONE
