Maybe First Steps To Living In My Shed
Started by
maybach
, Nov 18 2010 09:41 PM
10 replies to this topic
Posted 18 November 2010 - 09:41 PM
hi guys after owning my vx for almost two years now its time to fit a supercharger..
i will prob be asking what you guys may think are easy questions but i'm unable to find any reference to em on here etc.
so after a very long time and parcels that have gone twice round the earth i am redy to get started. well nearly can anyone please tell me why cs supply the alloy t piece and temp switch and where or whats it for?.
not posted much but this could all change ill keep updates as things progress.
its all f.l.d's fault he took me out in his car on a saturday at the cat n fiddle anyway
Posted 18 November 2010 - 09:54 PM
Oh dear! All my fault.
'Fraid I dont know the CS piece you mean but I'm happy to help out where I can.
Posted 18 November 2010 - 10:19 PM
Probably you mean an alu joiner for the heater hose you have to cut/modify for the SC conversion.
The CS remaps suffer sometimes from "random" ecu faults that turn your fan on constantly. (no EML!)
CS solution: fit an independent T-sensor in the cooling hose joiner and connect fan relay with this instead of with ecu. As a bonus the fan switches on earlier than 106°C.
(Please correct if wrong.)
Posted 18 November 2010 - 10:23 PM
My fan comes on occasionally. Error code comes up as running lean. Only occurs when the map switches from the low rev map to the high rev map. I believe there are 3 maps, cold low rev, hot low rev and high rev. I may be wrong, its just what I've been told.
Posted 19 November 2010 - 01:49 PM
Yep,
Spoke with the Dutch guy that cracked the Z22Se ecu about this CS remap and according to him it's a bit bodged together. It sort of works, but on these transition parts the ecu cannot calculate the right fuelling.
Posted 20 November 2010 - 12:04 PM
ahhh yes i understand its these little bits of info that all add up to get a better picture. so is the cs map good enough or are other maps available and if so who's doing em.
i take it one map does all applications whether charged cooled or not.
also which is the best or most usable/easy to get hold of throttle body to use.
my aim is to have it done the best way possible so not to fall into anytraps when i turn up for rolling roading.
Posted 20 November 2010 - 12:47 PM
The cs map is fine. You can ask them to double check thia area on the rollers to get it spot on. As far as I know no one else maps SC cars.
WRT throttle I'd recomend the 68mm LSJ one although CS can deal with the OE one.
Posted 20 November 2010 - 01:04 PM
Courtenay supply a base map to get your car to them, then they adjust the map for your car, it's not 100% perfect and there might be a few spots which aren't ideal but generally the mapping works very well
Posted 22 November 2010 - 09:14 PM
cheers guys for your info, gonna strip it down in a few weeks .
but first gotta have a thrash round cadwell in couple of weeks
while its in timid tune
i'll post some pics up when i start
exhaust manifolds who's cheapest or best or expensive or is it better to cobble one together?
Posted 22 November 2010 - 09:40 PM
A good start to avoid any issues when you go for the rolling road is fit an uprated fuel pump first. I know a few on here who have had to have the mapping pegged back as their original fuel pumps have not been up to the job.
Posted 29 November 2010 - 08:49 PM
hi yes thats something i was gonna change as mines a bit noisey. what do people fit as a replacement uprated item
