So This 'Flat Spot'
Posted 21 January 2011 - 09:52 AM
Posted 21 January 2011 - 10:00 AM
Posted 21 January 2011 - 10:13 AM
the map is a courtenay stage 3 from 2007, as you can see nice overboost , the turbo can't really flow enough at the top end for big bhp figures but the low and mid range torque is very useful on road and track.
Posted 21 January 2011 - 11:08 AM
2-3psi doesn't sound right at all to meAnyway, when flooring (as in full-throttle) the boost peaks about 10-12psi around 2,000rpm and backs off to about 8-9psi up until 3,000rpm. At this point it decreases, to around 2-3psi i reckon (may actually be even less - almost no boost at all) and the car feels like it hits a virtual brick wall. By 4,000rpm it is picking back up again and the next couple of thousand RPM see's the boost increase once more.
Posted 21 January 2011 - 11:32 AM
Posted 21 January 2011 - 11:36 AM
Nor me either, which is why i'm interested to see if anyone has a graph (preferably with boost plot) of a standard car.
Can't help feeling it must be something else apart from just the mapping/flat spot. Which is why i was wondering if it was intake pipe, dump valve or actuator arm.
As long as i haven't bought a pup
G
Posted 21 January 2011 - 11:49 AM
As long as i haven't bought a pup![]()
G
I get the same thing in mine. The first time it happened, I thought it was fuel starvation or something.
Loads of power up to about 3200 RPM, then it's almost like I've come off the throttle, then loads of power again from about 4200 onwards. I'm considering a remap just to get rid of it - I don't really want more power but it would be nice to have smoother delivery.
Posted 21 January 2011 - 11:54 AM
G
Reassuring to hear it's not just mine...
Do you have a boost guage - do you know what is happening to your boost?
Would be good if i can persuade an experienced VXT'er to come out as a passenger to give their opinion (promise i'm not a nutter).
G
Posted 21 January 2011 - 11:58 AM
G
G
If you end up coming round my way, can take you out in a stage 2 prepped car and stage 4 but agree stg2 more than enough will less comp for on road manners
I would never run a stage 4, stage 2, 5 or Tsi power
DG
Oe has a def flat spot but should not be that bad? Would need to go out in it to confirm fully but std map is a bit pants imo
Posted 21 January 2011 - 12:00 PM
the 'flat spot' area is where the measurements for the EU emissions figure is taken.
That's right, 4000rpm. Think it's noise rather than emissions though.
Bikes suffer from it too. All remaps seem to be able to fill the hole in.
Posted 21 January 2011 - 01:56 PM
DG
I expect i'll go for stg2 at somepoint, but for now i want to make sure it is running correctly as a standard car. So in the meantime it sounds like i need to track down what is making the boost drop by so much...
If this really is just a fault of the map, then i cannot believe that any automotive engineer would sign this off.
G
Posted 21 January 2011 - 01:59 PM
DG
G
I think we might need to check the vacuum hoses for any leaks and it might be a good idea to replace the boost control solenoid and the spring pre-load on the actuator.
Posted 21 January 2011 - 02:14 PM
DG
G
good start Steve, you know the suspects
DG
Posted 21 January 2011 - 03:12 PM
I don't think you've bought a pup G. When Whippet took me out on the test drive of my future toy I think we were less than a couple of miles in before I said "well, you can definitely tell this was mapped at Flatspot City". As you know, mine is standard with just the larini backbox.As long as i haven't bought a pup
G
I had the same thoughts about the intake pipe collapsing slightly but when I asked elsewhere it seems that people weren't fitting the pricey alloy pipes to fix this issue.
I'd say that mine has that dip just below 3k and starts to get back on it properly just under 4k. As mentioned, it's almost as if your foot has slipped slightly off the throttle. I always had it in mind to go for a mild map but I may well lose the pre-cat beforehand anyway so I'll let you know if it makes a difference. It won't be for a little while yet though - got some other bits to do on it first.
Part of the problem is that now you've driven it a few more times (probably more than I have with mine now) you've gained enough familiarity to spot the niggles and focus on them. A condition curable with money
Posted 21 January 2011 - 06:12 PM
Posted 21 January 2011 - 07:30 PM
Curves from TIS, so just a mapping issue[attachment=22714:00031319-torque and output curves.pdf]
Very informative. I must arrange remap.
Posted 22 January 2011 - 10:24 AM
Posted 22 January 2011 - 10:54 AM
Posted 22 January 2011 - 05:18 PM
Posted 22 January 2011 - 06:10 PM
