I d like to ask something weird. Can i swap the z22 with a z18? or the recent z18xer (vvt)?
(there is always a reason for...
Posted 25 January 2011 - 06:19 AM
Posted 25 January 2011 - 09:22 AM
Edited by NickB777, 25 January 2011 - 09:22 AM.
Posted 25 January 2011 - 09:45 AM
Why? what have they got that yours doesn't
Posted 25 January 2011 - 09:49 AM
Posted 25 January 2011 - 10:31 AM
Posted 25 January 2011 - 10:56 AM
2ltr turbo should be cheaper then
and quicker
Posted 25 January 2011 - 11:08 AM
Posted 25 January 2011 - 11:24 AM
Posted 25 January 2011 - 11:29 AM
Imagine de-stroking the engine is going to take some kind of proof and also there is going to be some work again to get it working correctly
DG
Posted 25 January 2011 - 12:50 PM
Posted 25 January 2011 - 01:01 PM
Posted 25 January 2011 - 05:17 PM
Posted 25 January 2011 - 06:01 PM
and quicker
You can put almost any engine you want in but as for what will bolt straight in and work on the oe ecu setup not as sure on the n/a side of things without any real cost or time
DG
Would changing the crank to the Saab B207 one not reduce the capacity below two liters? Not sure if the trigger wheel is the same though.
DG
In that case going turbo is probably best, or maybe a Redtop XE?
if you use the matching F23 gearbox then you can fit a 1.8 engine
Posted 25 January 2011 - 06:05 PM
Posted 25 January 2011 - 06:11 PM
Posted 25 January 2011 - 06:19 PM
b207 has a different trigger wheel so would need external trigger wheel and crank sensor
i have a crank rods and pistons if you wanted to do this
Posted 25 January 2011 - 06:52 PM
As a matter of interest how much extra will it cost you per year? Is the annual saving not going to be offset by the cost of modification and paying 'modified' insurance premiums?
