A Decent Front Splitter
Posted 29 January 2011 - 09:07 AM
Posted 29 January 2011 - 09:09 AM
Posted 29 January 2011 - 12:30 PM
There are a few factors. Does it help generate more grip. Does it effect the balance of the car. Does it rip/not rip the front clam off or splinter when you go over a speed bump. Does it look cool?
I would be all for one of these if it helped with front end grip. However I have a feeling that if anything it would at best (if there was any effect at all) slightly increase the total front and rear downforce.
I certainly would not want to fit sill extensions to make the most of the splitter.
Paul
Posted 29 January 2011 - 12:40 PM
Posted 30 January 2011 - 12:33 AM
Posted 30 January 2011 - 08:56 AM
Edited by Nev, 30 January 2011 - 08:57 AM.
Posted 30 January 2011 - 09:04 AM
Posted 30 January 2011 - 09:34 AM
http://www.vx220.org...tter-group-buy/
Link to what appears to be a very popular front splitter.
in fact, this splitter is still in a first group buy in the german VX boards, so I would say, it is not really popular yet. it's a brandnew part.
I drove the original VX and since 2006 I had two different front splitters mounted. I would not drive without. From my experience a well designed front splitter together with an even well designed rear diffuser are the real deal if it comes to higher speeds, they significantly increase high speed stability. with the original aerodynamics the car felt very unstable both on front and rear axle doing 120mph or more. long highway bends turned out to be freaking, several times I went through moments thinking I will lose the rear end. After the upgrade to the first splitter from AK Motorsport and a carbon diffuser from Regelin / VX-Performance I had an absolutely new car in matter of high speed stability. I can drive 160+mph and the car sticks to the road. even if there are ground waves / bumps there is not one problem, you can literally feel the car being sucked back to ground, following the tarmac very sharp and precise.
of course these modifications improve trackday performance in the same way.
owning a VX, first things to do are wheels, suspension and aerodynamics, because all these thing are crap in the original VX. you can get so much more out of the car doing these modifications, you will not believe it until you experience it by yourself.
these are my two splitters I had/have on the VX:
2006-2010 - Regelin carbon read diffuser + AK Motorsport front splitter (originally created for a Subaru WRX)
2011+ - Maintools (ex Dempert, ex Regelin) front splitter + RaceStyler aluminium rear diffuser
the 2011 setup is not tested yet but I am very convinced it will be a further improvement:
- the front splitter is mounted absolutely bulletproof, much better than the AK, it turns out to be a part of the front clam without any openings or slits where air my press in
- the underfloor is now an even aluminium plane right from the front end to the outer end of the diffuser, no gaps, no steps, absolutely even
- the diffuser made from aluminium is immune to the heat radiation emitted from the catalyst which is a major topic if you have removed the rear part of the underfloor replacing it with the diffuser for cooling purposes. had my carbon diffuser damaged from the emitted heat and was forced to go for aluminium as a solution
so in a nutshell: splitter and diffuser = great improvement in terms of downforce
Edited by cs_, 30 January 2011 - 09:38 AM.
Posted 30 January 2011 - 09:43 AM
Posted 30 January 2011 - 09:46 AM
Posted 30 January 2011 - 11:16 AM
Posted 30 January 2011 - 11:19 AM
Posted 30 January 2011 - 12:36 PM
That's a fab looking car, and I've had vx-performance.de recommended to me by a German Speedster owner.Do you have certification available for any of these modifications? I can imagine the Swiss MOT guy just having a laugh.
Posted 30 January 2011 - 01:50 PM
Posted 30 January 2011 - 05:29 PM
Posted 30 January 2011 - 07:15 PM
Posted 30 January 2011 - 07:25 PM
I had to choose the gas stations by their driveway. only the flat ones could be accessed. speed bumps strictly had to be avoided.
As I have brushed the top of a speed hump with my front number plate before, I end up doing that anyway.
Some petrol stations with a short & steep slope leading on to their forecourt
Speed humps seem to be unavoidable though (in London side roads - they are everywhere!).
Posted 22 February 2011 - 02:44 PM
version 1 :
version 2 :
version 3 :
version 4 :
version 5:
Personal drawing welcome
Posted 22 February 2011 - 02:45 PM
