Best Value For Money Intercooler Coolant.
18 replies to this topic
#1 Nev
Posted 10 February 2011 - 07:20 PM
Whats the best coolant to put into my intercooler circuit? And why is it the best. I don't plan to pay top dollar for some pseduo-science stuff ! Discuss... please. Nev.
#2 siztenboots
Posted 10 February 2011 - 07:25 PM
100% pure water performs the best but may react with metals in your system also freeze in winter
#3 Nev
Posted 10 February 2011 - 07:29 PM
Considering our last 3 winters I think water might be a risk Steve !
#4 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 10 February 2011 - 07:56 PM
As above water itself is the best coolant. Best to get some and find out what %age mix covers you down to what temperature you thing the car will face. You may get away with a 70-30 mix but not sure what that covers down to. Prob around -10c. use the same percentage mix in your engine too as you want the best cooling there too
#5 Tail slide
Tail slide
  • 241 posts
  • Interests:Fast road cars, trackdays & sprints, snowboarding.
Posted 10 February 2011 - 08:12 PM
'Water wetter'; sounds bizarre but really works in my experience with other hot-running engines and is 'good science'!
Best with circa 70% water/ 30% antifreeze for anti corrosion.
#6 KurtVerbose
KurtVerbose
    His Serene Highness
  • 3,855 posts
  • Interests:Big baps.
Posted 10 February 2011 - 08:42 PM
Yes, no question. Water is a fantastic coolant apart from it's low boiling temperature. Not a problem for an intercooler.
Corrosion and freezing are a problem though.
#7 Tail slide
Tail slide
  • 241 posts
Posted 10 February 2011 - 09:14 PM
Takes just a couple of degrees off head temps, but that's where we need it. Water Wetter test; http://www.importtun...ives/index.html
Edited by Tail slide, 10 February 2011 - 09:15 PM.
#8 alanoo
alanoo
  • 1,324 posts
Posted 10 February 2011 - 10:16 PM
like in F1, nanoparticles charged distilled water :)
#9 SteveA
SteveA
  • 9,158 posts
Posted 11 February 2011 - 10:07 AM
I use this stuff; http://www.halfords....tegoryId_229902 Stops it freezing in winter thumbsup
#10 siztenboots
Posted 11 February 2011 - 10:11 AM
I use this stuff;
but you are just paying for the added water to make it readymix, I just buy the concentrate stuff and mix to my own preferred concentration for summer or winter use.
#11 FLD
Posted 11 February 2011 - 01:44 PM
If you dont fancy liquid sodium have a look at evans' coolant. Its what Darton recomend for their LSx wet liners.
#12 nicollow
nicollow
  • 3,801 posts
Posted 11 February 2011 - 01:53 PM
I wouldnt put coolant in an intercooler, cos it'll end up in your engine!! :P Im pesuming you mean a chargecooler? I just used water with a touch of antifreeze. Its got corrosion inhibitors and means it wont freeze in the winter. Double win...
#13 siztenboots
Posted 11 February 2011 - 01:57 PM
downside of the evans coolant is having to recalculate flow rates and pump sizing. The benefit iirc was the evans stuff was much better at near to boiling conditions , which you hopefully won't see in post turbo compressor air temps.
and iirc ,its not cheap stuff either.
#14 FLD
Posted 11 February 2011 - 02:07 PM
You do indeed remember correctly. Its B*stard expensive stuff! Fortunately for me I wasn't paying for it when I was using it. Its supposed to be good on the liners with the extra cooling chanels round the top so I guess that makes sense on your first point.
#15 Nev
Posted 11 February 2011 - 02:10 PM
Obviously my CC circuit isn't going to get any where near boiling point, so I guess water with a moderate amount of alchol (say 30%) will cope with winter.
#16 Winstar
Winstar
  • 4,264 posts
Posted 11 February 2011 - 02:49 PM
use a coolant (ethyl glycol) with OATS mixed to 30/70 with distilled water will protect to -15'C as you won't need the increased boiling point that a higher concentration would give you. The OATS is the important bit as it stops it coroding the Alumimium. You can use water wetter but I doubt you'd see much difference in a CC system as the temperature differences are alot lower than an engine cooling system.
#17 slindborg
Posted 11 February 2011 - 03:06 PM
ANY air charge cooling mechanism between the Turbo and Engine intake is an intercooler... well to be pedantic they are actually AFTERcoolers as they are post turbo/pre engine. A 'real' intercooler is between charge circuits, eg small turbo -> cooler -> Next turbo -> engine.
I have seen coolers on exhausts too, and they have been called aftercoolers too :lol:
Edited by slindborg, 11 February 2011 - 03:07 PM.
#18 Zoobeef
Zoobeef
  • 11,103 posts
Posted 11 February 2011 - 03:49 PM
On solme of the lorrys we use they have coolant runnung through the pipe between the 2 turbos and running through the egr pipe bringing those temps down from about 700c to 200c
#19 Nev
Posted 11 February 2011 - 05:24 PM
Thanks Rob, I''l look into OATS.
