Heatshield For Rear Clam Question
Posted 22 February 2011 - 09:08 AM
Posted 22 February 2011 - 10:30 AM
Posted 22 February 2011 - 01:45 PM
Posted 22 February 2011 - 09:17 PM
Posted 22 February 2011 - 10:20 PM
Mine is Nimbus, cut to size and mounted in the same way as the original one. Boot nice and cool inside.
Nimbus Lite or Nimbus GII?
I'm thinking while I've got the rear clam off might as well get some other things done.
Posted 23 February 2011 - 07:47 AM
Posted 23 February 2011 - 08:02 AM
Posted 05 April 2011 - 09:38 AM
I binned mine. Fine without it so far
interesting because VXL want 93178003 - £95.70 , so I may give that a miss. I'm keeping the backbox blanket shield though.
Posted 05 April 2011 - 10:27 AM
I binned mine years ago as well and noticed no difference to boot temperatures. Although I did very little driving in traffic so always had good airflow through the engine bay.interesting because VXL want 93178003 - £95.70 , so I may give that a miss. I'm keeping the backbox blanket shield though.
The rear clam vents Jimmy and I have are definitely a factor in making the heat shielding superfluous. It would be worthwhile keeping an eye on the temperatures in there after track sessions to be on the safe side though. Although if you have a diffuser mounted on a low setting most of the heat can escape below the clam anyway.
Edited by garyk220, 05 April 2011 - 10:29 AM.
Posted 05 April 2011 - 11:49 AM
Posted 05 April 2011 - 11:55 AM
Posted 05 April 2011 - 12:25 PM
Posted 05 April 2011 - 12:29 PM
Both off NA's:
Can anyone tell me if this is a homemade jobbie:
Posted 05 April 2011 - 12:30 PM
Posted 05 April 2011 - 12:31 PM
Posted 05 April 2011 - 12:33 PM
Thanks Joe, is that a Nimbus one then?
Can you give me a rough idea what I should be asking for it?
Thats a nimbus one. I'd guess its a full sheet which is about 45 quid new from nimbus motorsport. I'd guess you should be around 30-35 quid for it given its in fine fettle.
Posted 05 April 2011 - 12:34 PM
Posted 05 April 2011 - 12:37 PM
