Edited by NickB777, 03 March 2011 - 10:54 AM.
Z20Let Trigger Question
Posted 03 March 2011 - 10:53 AM
Posted 03 March 2011 - 01:11 PM
Posted 03 March 2011 - 01:23 PM
Are you talking about missing teeth in the cam wheels on a standard Z20LET ?
I just put a cam sensor on my new engine yesterday - there are no missing teeth on the cam wheels.
i think he wants the angle of the sensor for instance on a z20net its 60-2, 117* before deadlock
Posted 03 March 2011 - 01:31 PM
Edited by NickB777, 03 March 2011 - 01:34 PM.
Posted 03 March 2011 - 02:19 PM
So on Z20NET (= Saab B207 = GM 2.0 LSJ ) it is 117* before TDC cyl 1.
Same question => where exactly is the 117° measured? Flank? Exact middle of the 2 missing tooth??
Posted 03 March 2011 - 04:38 PM
Posted 03 March 2011 - 04:41 PM
z20NET and Z20LET are most likely different
the above z20net was just an illustration, the GM family 2 block will be different.
But is Nick using a Z20NET position sensor already in the block?
Posted 03 March 2011 - 04:44 PM
Posted 03 March 2011 - 04:57 PM
No am using the alpha trigger wheel Bracket so the 60-2 bolts onto the crank pulley next to the s/c belt
The sensor will be relocated from the z22se oem position and extended wiring used(Vocky has done this already)
thank god i dont have this problem
Thanks Joe
Edited by NickB777, 03 March 2011 - 04:57 PM.
Posted 03 March 2011 - 04:59 PM
Think they generally go from the back of the last tooth before the gap, well aftermarket ones tend too
Posted 03 March 2011 - 05:00 PM
Posted 03 March 2011 - 05:09 PM
Posted 03 March 2011 - 05:13 PM
sorry i could not be of much help!! didnt realise how critical the angle has to be
No problem it's just a going to be a pain to setup up at the correct angle as it's difficult to get to
well at TDC its going to be tooth 19,20 or 21 , and each tooth is (360/60) , 6 degrees.
Just googling and had 19,20 and 21 figures sofar , still trying to find a definitive answer for you Nick.
Thanks Steve, will keep looking also
Posted 04 March 2011 - 01:24 AM
I know Nick is using the Z20LET ecu stuff, but I have the LSJ ecu/ Z20NET lying around. So 117° it is for me, but where to measure?
Posted 04 March 2011 - 07:19 AM
