Is 4 Litres Of Oil Enough For Oil Change?
28 replies to this topic
#1 insanojackson
insanojackson
  • 228 posts
Posted 01 September 2011 - 08:22 AM
Noticed a lot of oils come in 4 litre cans now, will 4 litres be enough for an oil change on the n/a??
#2 bunsenburner
bunsenburner
  • 1,042 posts
Posted 01 September 2011 - 08:24 AM
I normally use 5 litres.
#3 The Batman
Posted 01 September 2011 - 08:27 AM
No. Good sales technique if they do sell in 4L but I have never seen a 4L bottle!
#4 insanojackson
insanojackson
  • 228 posts
Posted 01 September 2011 - 08:30 AM
not that I am buying from tesco but look at this page. http://www.tesco.com...3&Ne=4294965303
Loads of 4 litre sizes
#5 Kieran B
Kieran B
  • 1,101 posts
Posted 01 September 2011 - 10:09 AM
i bought two 4L bottles when i did mine recently, i put in just over 5L. (5.4 i think) but it makes sense to have some oil at home as mine seems to drink it when i thrash it. like joe said, good sales tactic. chinky chinky
#6 JG
JG
  • 13,617 posts
Posted 01 September 2011 - 11:30 AM
yep, you need 5.5 to do it properly (in filter)
#7 MellowYellow
MellowYellow
  • 665 posts
Posted 01 September 2011 - 03:56 PM
:yeahthat: small (1 litre) bottles cost a fortune as well :angry:
#8 slindborg
Posted 01 September 2011 - 04:05 PM
I think only my shonky old nova would take 4L of oil, almost everything else will use 5+ litres..... cunning and shitbag marketing ploy
#9 The Batman
Posted 01 September 2011 - 04:07 PM
7L in mine :( :lol:
#10 Phear
Phear
  • 1,125 posts
Posted 01 September 2011 - 06:56 PM
I've generally needed at least 5.5 to do mine. 5 will usually get the dipstick to max until first run then a top up after.
#11 BlueVX52
BlueVX52
  • 517 posts
Posted 02 September 2011 - 01:42 PM
As above i have always used over 5L Dan
#12 insanojackson
insanojackson
  • 228 posts
Posted 02 September 2011 - 01:58 PM
Cheers for the advice, looks like i will be buying 2 cans of oil then lol
#13 bunsenburner
bunsenburner
  • 1,042 posts
Posted 02 September 2011 - 02:03 PM
If you have an SC, then you will need just over 5 litres after a short drive then add 1 litre, after another short drive add another litre, after another short drive add another litre etc etc etc
#14 Kieran B
Kieran B
  • 1,101 posts
Posted 02 September 2011 - 03:01 PM
etc etc etc
:lol:
mines not that bad any more.. only when i give her a good seeing to on track :P
#15 The Batman
Posted 02 September 2011 - 03:51 PM
or put some proper oil in it and you shouldnt have to :rolleyes:
#16 bunsenburner
bunsenburner
  • 1,042 posts
Posted 02 September 2011 - 03:58 PM
Don't think it's down to the type of oil, although something thicker than normal might help.
#17 Phear
Phear
  • 1,125 posts
Posted 02 September 2011 - 04:30 PM
Halfords do some 5w50 fully synth stuff which is 20% off atm, I've just changed mine out for it :)
#18 The Batman
Posted 02 September 2011 - 04:40 PM
yup i suggest 5 or 10w50 if you are burning that much oil then its simple. your engine has internal problem or there is a leak
#19 slindborg
Posted 02 September 2011 - 05:25 PM
Millers CFS 10/60, my boggo N/A LOVED the stuff :) and it was only £30 for 5L from my local factors :)
#20 bunsenburner
bunsenburner
  • 1,042 posts
Posted 03 September 2011 - 07:51 AM
I did exaggerate a little for comic effect Posted Image
It's about 500ml for 250 miles plus a heavy trackday on a double ester fully synth 5w 40. No visible leaks so it must be being burnt off. I'm going to try something thicker once my current stocks have been run down, and see if that helps.
