Project Ginge
#121
Posted 26 January 2014 - 12:35 PM
#122
Posted 26 January 2014 - 06:40 PM
#123
Posted 01 March 2014 - 08:40 PM
Ok, it's been a little while, we have had a nightmare with the weather and our unit where my car car is kept. For 3 weeks now its been a nightmare "Convertible" style workshop....not ideal.
It was fixed this week, so after popping down every couple of days to check all parts and tools were still there, it was in no real state to work on the car, after a quick tidy up, i broke into some of the various packages which had been arriving over the last couple of weeks.
Luke Tow Strap
E-Tech Short mirrors (Will be sprayed as the carbon "Effect" is well, not effective.)
Door Grab Straps....for a plan i'm still formulating
Slave Cylinder number 4.......
Wired up switch panel ready to butcher the OEM ones
Black Fuel filler bolts
Carbon Gear knob
I have also (Contraversionally) Removed the middle grove and start button recess from my Dash and covered with Alcantara. The flash makes it look Purle but it is Black. Didn't cost much as i only used cheap material, there are a couple of bits i'm not happy with so this may end up being done again properly by me or DTT
Gear knob looks really good up close, just need to change the base bit from Silver to Black
#124
Posted 01 March 2014 - 08:43 PM
I have Also removed my Steering wheel....how tense is the Airbag bit!!!
I was all set to get a removable boss and new wheel but was a little concerned at some of the insurace companies who may have an issue, found a chap from and old link fro here and getting it re-done in Alcantara....will post up the results.
Probably not much more to happen for a few weeks apart from fitting the above, i have however sent an email to our resident "Whiners" about booking an appointment for their maigic. Fingers crossed, April could be the time.
Then it will just be the body work to sort.....and a million other things i find along the way. This began as a "refresh" but i think now definately qualifies as a "rebuild"....and doesn't my bank balance know it.......
#125
Posted 02 March 2014 - 12:03 AM
#126
Posted 02 March 2014 - 12:04 AM
#127
Posted 02 March 2014 - 09:19 AM
#128
Posted 02 March 2014 - 01:43 PM
Good. In my drunken state I was worried you were about to apply for a Darwin Award. Normal service resumes. Carry on...Exactly that Graeme, couldn't be bothered to faf with insurance and have always liked the OEM wheel. Will get it recovered as its got a few marks on it, then i can put the airbag back too.
#129
Posted 22 March 2014 - 12:42 PM
1 step forwards......84 steps back ......
So i finally decided i had to remove the engine again for the latest broken slave cylinder. I had put it off for a few weeks now but with a bit of persuision the engine...which was running....is now out for 4th time. Super!!
I have the new parts for it but will be waiting until i need to the get the engine back in before fitting them so that there will be more eyes watching me hopefully to see what the hell i'm doing wrong!!
I'll be replacing the red clutch cover with the original cover and hoping the new clutch plate has not been damaged!
A few little jobs this week once the engine was out,
Now that Fez is off and running with the replacement lights, i felt brave enough to see if i could split mine to see if i could fit the broken projector lamp which is loose, front lense off in one piece....phew
Then prgress stopped. After an hour or so of heating the glue and pulling the sealent off the unit i still couldn't split it. I think thye have used a hefty amount and well, i got bored.
Fitted the switch panel i made with from some 3mm Carbon Sheet, still undecided whether i like it but...it's in now.
#131
Posted 22 March 2014 - 12:48 PM
And the best thing this week is my Steering Wheel arrived back!
Excellent service from the guys at Royal Steerign Wheels. Jack has done a great job.
It feels really good and saves all the hassle of losing the Airbag.
For info, i have Black Alcantara with a Black Stitch, Red Leather Middle Marker and it was £135 + £10 postage. turned around in 9 days. Lovely.
#132
Posted 22 March 2014 - 04:38 PM
#133
Posted 22 March 2014 - 06:28 PM
Badly, in my experience.How does alcantara wear with bare hands..?
#134
Posted 21 April 2014 - 06:43 PM
Well, thats another month gone by!!
Back down to the workshop today to remind myself of how far behind i am in this whole Saga!
A Parcel from Tom was waiting for me on return from my holiday, so it was Heater 1st on the list today :
Battery Out
Old Heater out.....
The good thing about having taken everything apart recently.....all the bolts come undone!
Slight difference between the 2 :
Luckily this one is replaced with the new kit....it had seen better days
After removing the above, the new connection wouldn't go through the gromit, removed it and the wire just about went through with a little persuiasion
New unit in
I didn't have the m6 screws in amongst the kit, but had a few leftover from my JG bolt kit so all was good
I went for the "electrical tape around bolt and allen key" method to ensure no dropped bolts into the fan when putting the radiator back on
Plugged in the wires as per the Guide on here
Done
Just need a big jubilee clip for the hose on the fan
As the engine is out again, there is not way to test yet but i'm sure it will all be fine
#135
Posted 21 April 2014 - 06:51 PM
Finally got round to putting the seat and harness in to check for fitment
I had spoken to JJJ about the seat as i was sitting quite high and knees touching the wheel, after speaking to the guys at JK they could make me a lower subframe, but it would be fixed which is not ideal.
Now it is in properly it seemed a lot better so i will leave it as it is and see how we get on. I will probably get the "Pads" re-covered....although a new set is only £70 so might be easier.
I bought some Alloy indicator stalks on here when they appeared in Matt Black so thought i would fit them today....After taking the cowl off and looking i could not work out how they fitted.......then a quick search on here "Cut the originals off".....oh simple as that
Well, when in rome.........
No going back now.
New one on and tightend up
Repeat ont he other side
Done
#136
Posted 21 April 2014 - 07:02 PM
I bought a set of Robin Louvres on here a while ago and after treating myself to nuermous new power tools in B&Q this weekend i thought i would have a go at cutting the out. It didn't go well with the 1st attempt.
I have cut too much off on a couple of the vents themselves so they look a little out of place compared to the rest, after speaking to Martins (Thanks for all the advice!!) i think i can rectify it.
So a change of tact :
THIS IS IN NO WAY A GUIDE!! i AM LITERALLY MAKING IT UP AS I GO ALONG!!!
Drill the corners of the vents
Dremel along to the holes each end
Then dremel in a diagonal through the middle.....being careful not to cut the vents themselves
Snap the middle pieces out from the weakend holes
Repeat MANY times
Excuse the wonky cutting, this is my 1st attempt at anything "Bodywork" releted. Now its time to get the files out and tidy up the edges and generally make them look a little more presentable.
Thats it for today, Nelly is trying to tempt me with items so the next update could include a variety of things! Hoping to get the new slave unit into the engine, replace to clutch cover and get the engine back in next time....just want it running now, it's been far, far, far , far, far too long.
#137
Posted 21 April 2014 - 07:03 PM
It's progress.....
#138
Posted 21 April 2014 - 07:07 PM
#139
Posted 21 April 2014 - 07:09 PM
#140
Posted 27 April 2014 - 09:59 PM
Carpets was the 1st job this week, after a delivery from Fred.
Rather than just cover all the dirt over i decided to make the effort and give it a good scrub before putting the carpet down
After
I put the "Mat" bolts in to hold the carpet in place then added the double sided tape ready to hold it down to the floor
The side panels are a little short so i've emailed Fred to see if i have done something wong
Main section in and down with the mats back in place
PPPPP
As the side panels are not on yet, nothing is bolted down but you get the idea. I have added the Passenger seat back in, but no doubt that will end up getting changed over for something.
