Edited by christurbo, 23 May 2006 - 02:36 PM.
Posted 23 May 2006 - 02:35 PM
Posted 23 May 2006 - 02:37 PM
Posted 23 May 2006 - 04:02 PM
Posted 23 May 2006 - 04:04 PM
Posted 23 May 2006 - 04:27 PM
Edited by christurbo, 23 May 2006 - 04:28 PM.
Posted 23 May 2006 - 05:37 PM
Posted 24 May 2006 - 09:16 PM
Why do you say that - you tried???
Posted 25 May 2006 - 07:12 AM
Edited by Arnie, 25 May 2006 - 07:18 AM.
Posted 25 May 2006 - 07:31 AM
Edited by christurbo, 25 May 2006 - 07:37 AM.
Posted 25 May 2006 - 08:06 AM
Posted 25 May 2006 - 08:16 AM
Edited by christurbo, 25 May 2006 - 08:17 AM.
Am I right in thinking the the standard VXR220 has the Exige suspension AND the exige rear subframe?You will have the first hybrid VX Exige!
Posted 25 May 2006 - 08:19 AM
Ben
Posted 25 May 2006 - 11:31 AM
Posted 25 May 2006 - 11:41 AM
You equate harder spring rates with 'improvement.' That is rather a gross simplification.
My concern would be the significant difference in 'balance' between the two systems. The VX rears are approx 15% stiifer than the fronts. The Exige rears are 30% stiffer. This will alter the handling balance of the car, a stiffer rear will be more loose.
If you go ahead and fit that exige spoiler then you will have the first hybrid VX Exige!!!!
Edited by christurbo, 25 May 2006 - 11:45 AM.
Posted 25 May 2006 - 12:44 PM
Hang on a minuite!
Arnie - do you have S2 Exige suspension on your VX/Speedster???
If so post some photo's !!!!!
Also what is your opinion of them at the moment?? - All the 111R owners try and get some S2 Exige suspension as an upgrade to their current suspension when getting sticky rubber/track use.
My desire is to have a stiffer setup without having to go as hard as Nitrons/Ohlins.
PS. I have had confirmation from Plans that the 111R/S2 Exige have the same rear subframe as the VX.
Posted 25 May 2006 - 03:43 PM
Edited by christurbo, 25 May 2006 - 03:44 PM.
Posted 26 May 2006 - 06:04 PM
Posted 27 May 2006 - 08:58 AM
Posted 27 May 2006 - 09:03 AM
Edited by christurbo, 27 May 2006 - 09:05 AM.
