Clutch Options For A Stage 4 Tubby
Posted 23 April 2011 - 11:04 AM
Posted 23 April 2011 - 01:01 PM
Posted 23 April 2011 - 02:13 PM
Posted 23 April 2011 - 02:17 PM
Having had a paddle clutch (not on my vxt though) I'd say it was great when not an everyday car but could be a little too on/off especially if used in traffic regularly.
I'd have to think long & hard if I'd choose a paddle again even for fast road & some track use. If mainly track use I wouldn't hesitate though.
Be interested what other people think though if they've had one on a vxt.
Cheers.
I have a paddle clutch and have no problems with it at all. It is very on or off but I find it makes you plan your driving better especially at junctions. My car is a only a second car for sunny days so its fine. Not sure I would want one for everyday use if it involved a lot of traffic or hill starts!
Posted 23 April 2011 - 05:38 PM
Posted 23 April 2011 - 06:48 PM
Posted 24 April 2011 - 07:52 AM
Posted 24 April 2011 - 08:12 AM
Posted 24 April 2011 - 10:32 AM
same as you mate ..hoe do you tellDon't know which variety is fitted to my stage 4...feels quite heavy and easier to stall at junctions in comparison to a standard shed..
how can you tell?
Posted 26 April 2011 - 02:20 PM
Posted 26 April 2011 - 02:43 PM
Posted 26 April 2011 - 02:50 PM
...but could be a little too on/off especially if used in traffic regularly.
Nicol only has a couple of driving styles anyway, 1. No power,2. full power,3. lighting up the wheels while driving sideways.
Posted 26 April 2011 - 06:42 PM
I've tried standard, Sachs and helix now. I am currently on helix and was sceptical with 330BHP and even more torque. However it is great. I liked the Sachs but as I use the car every day I probably wouldn't go back to it as it was a bit more effort in traffic.
Andrew
When you say your running the Helix do you mean the heavy duty organic?
http://www.performan...2006/409626.htm
Cheers.
Posted 27 April 2011 - 07:17 AM
Andrew
Cheers.
Yes. Fitted by Plans
Posted 27 April 2011 - 08:09 AM
Andrew
Cheers.
Sounds like a good option then if it can handle that power ok.
Cheers.
Posted 27 April 2011 - 09:22 AM
Posted 27 April 2011 - 09:25 AM
Posted 27 April 2011 - 09:28 AM
The helix 6 leg paddel clutch is a pussy cat and more than fine even for your nan to drive - just adjust your driving style to take into account it is a paddle and will last fine and not slip
Would not even consider an organic tbh, they dont recover from extreme heat / slip and tend to be heavier on the pedal than the paddle which I find more work in trafic
Also there is not difference in cost
I also find the sacs 4 paddle fine as was the 4 paddle helix on my old one and love them all
True a paddle will eat your fly more but not so much that you will loose sleep, mine got REAGULAR abuse from road commute to track to drag strip and when removed was fine
DG
Thanks Duncan
I recon youre the man when it comes to knowing what can take a bit of abuse. Is there much difference between a 4 or 6 arm paddle? Should I just get the 6 and be done with it? Should I get the uprated cover and release bearing while Im at it too? Thanks again
Posted 27 April 2011 - 09:45 AM
Posted 27 April 2011 - 09:51 AM
4 paddle feels a bit more agressive in terms of smaller bitting point - if in doubt side step the clutchlol
That's how Nicol drives! Biting points stop the wheels from spinning!
