I've Just Had My Silencers Repacked At Chris Tullets...
48 replies to this topic
#1 MAXR
MAXR
  • 2,719 posts
Posted 27 July 2011 - 07:33 PM
Once again the noise levels were creeping up, last time out at Cadwell with Jimmy I was static noise tested at 3500rpm (a little white lie) & I was clocked at 102db. So after a visit today to Tullets both boxes were found to be empty....again! They were repacked with their latest stuff, fingers crossed! I also had a flexi Conector fitted at the same time, as the system was too rigid. Now I'm feeling lucky and may book Bedford for a Novice day for my other half.... :rolleyes:
#2 The Batman
Posted 27 July 2011 - 08:16 PM
I only live down the road max :poke:
#3 chris_uk
Posted 27 July 2011 - 08:28 PM
how much was a repack?
#4 hutchy
hutchy
  • 429 posts
Posted 27 July 2011 - 08:32 PM
How old was the exhaust? Doesn't really sound acceptable to me for such an expensive product (runs away and hides from the Tullet fans)
#5 MAXR
MAXR
  • 2,719 posts
Posted 27 July 2011 - 09:17 PM
The exhaust was packed almost a year ago with material they now no longer use. Mind you, it still only lasted for three & a half track days! The new material apparently should last longer? I will wait and see.... I was very happy with their service & was only charged for the flexi joint to be fitted. I think the new material was approx 2kgs in weight & would have cost around £60+ fitting for the two boxes. Still, much cheaper than throwing the whole thing away!
#6 techieboy
Posted 27 July 2011 - 09:22 PM
Not just a Tullett problem. I've had 6 or 7 different exhaust systems on this car and all of them have blown the stuffing out. The Tullett, with the higher grade AcoustaFil is the only one that hasn't (noticeably, at least) to date.
#7 MAXR
MAXR
  • 2,719 posts
Posted 27 July 2011 - 09:29 PM
That's good news, hope it lasts longer than just a few track days....
Matt,
6/7 different exhaust systems....that must be a record!
#8 techieboy
Posted 27 July 2011 - 09:32 PM
I didn't pay for all of them, thank God. I'm still on a quest for a decent but quiet one though. My Milltek was the best in terms of noise but no way I'd have been able to run it on the car as it is now. :rolleyes:
#9 hutchy
hutchy
  • 429 posts
Posted 27 July 2011 - 09:41 PM
That seems a bit ridiculous, I have never heard if any other type of cars clearing out packing so universally? Is it because we have such a short exhaust length compared to most?
#10 MAXR
MAXR
  • 2,719 posts
Posted 28 July 2011 - 06:45 AM
No, same length as everyone else. Not quite sure why it's burning out...Chris Tullets said that it had mostly emptied & crystallised inside both boxes due to heat. The new stuff should be good for 900 degrees, we'll see!
#11 bunsenburner
bunsenburner
  • 1,042 posts
Posted 28 July 2011 - 07:51 AM
Any opinions as to how frequently this needs doing? I've never even looked at mine. I'm sure noise is an issue for everybody who tracks, so perhaps a lot of noise limit issues could be solved by maintaining the packing inside the boxes, after all it should be a simple job to do.
#12 FLD
Posted 28 July 2011 - 07:52 AM
I thought noise tests were done at 4500 rpm (supposedly 3/4 max rpm)? Does it vary from place to place?
#13 bunsenburner
bunsenburner
  • 1,042 posts
Posted 28 July 2011 - 08:06 AM
I assume that was the "little white lie" on the static test.
#14 techieboy
Posted 28 July 2011 - 08:11 AM
I've had it measured at anywhere from 3000rpm to 5500rpm. It's not particularly consistent. Think the highest rpm I've had to hold it at was at Snetterton.
#15 alanoo
alanoo
  • 1,324 posts
Posted 28 July 2011 - 09:24 AM
Nop it's because our tuned maps are rough and not really optimized as no one could map the ECU as perfectly as it should so, especially the SC cars, are running skyrocket EGTs (basically due to the huge safety needed as they do not have post cooler air temp)
#16 hutchy
hutchy
  • 429 posts
Posted 28 July 2011 - 09:30 AM
Good to know thanks
#17 14500rpm
14500rpm
  • 381 posts
  • Interests:Boobs, Cars. Motorcycles.
Posted 28 July 2011 - 10:48 AM
On the subject of exhausts, is the OEM Turbo backbox much of a restriction on a S/C car? I'm thinking about using one instead of a Tullet/2Bular/whatever because of A) noise issues and, B) I'm tight.
Edited by 14500rpm, 28 July 2011 - 10:49 AM.
#18 Winstar
Winstar
  • 4,264 posts
Posted 28 July 2011 - 12:22 PM
It will be more restrictive that a stright through design, however it is 2.25" (I've got one mated to a piper 2.25" cat pipe) so bigger than the NA miltek, getting a bigger cat pipe is more important IMO.
Jonnyboy used to run one on his SC with a 2ubular cat but never had it on the rollers IIRC
#19 FLD
Posted 28 July 2011 - 01:23 PM
Mine was pooped after less than 500 miles. It drove to anglesea and had gotten freekin loud after about 3 laps. thumbsdown Some have obviously lasted a touch longer.
#20 CHILL Gone DUTCH
Posted 22 May 2013 - 05:06 PM
Hi max R how are you getting on with your wadding/packing in the exhaust did it last any longer??
sorry for bringing his thread back to life after so long   :lol:
