Idiots Guide To Hub Replacement?
21 replies to this topic
#1 AliM
AliM
    insert humour here
  • 9,146 posts
Posted 09 August 2011 - 12:24 PM
Found these instructions, but is there anything else I need to know? or could anybody offer any tips on how to make it easier? ("take it to the professionals" doesn't count)
Cheers
Ali
It is an easy job (apart from undoing the bolts) a quick step through is like this:
1) jack up
2) wheel off
3) undo wheel hub nut (castle nut)
4) caliper off
5) disc off
6) undo the three hub bolts
7) hub off
8) replace in reverse order
#2 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 09 August 2011 - 12:28 PM
while it may look easy, i can garante one of the bolts has desided to stay where it is forever...
#3 Winstar
Winstar
  • 4,264 posts
probably a piece of scafold pole to get enough force to get the bolts off
#4 SteveA
SteveA
  • 9,159 posts
Posted 09 August 2011 - 12:33 PM
:yeahthat:
I managed to get both front hubs off without major issues but I did have to jack the car up really high and use a 2 foot breaker bar with an impact socket. Don't use a cheap socket as misshaping the bolt heads even slightly will see them need cutting off with an angle grinder thumbsdown
#5 AliM
AliM
    insert humour here
  • 9,146 posts
Posted 09 August 2011 - 12:36 PM
:yeahthat:
ah ffs :( it's me, it is not going to be an easy job.
Edited by AliM, 09 August 2011 - 12:36 PM.
#6 SteveA
SteveA
  • 9,159 posts
Posted 09 August 2011 - 12:38 PM
An hour per hub tops for a pro to do it plus they will have air impact wrenches which makes things massively easier. The difficulty will depend on the level of corrosion there. My fronts came off OK but I couldn't move one of the rear bolts at all.
Edited by SteveA, 09 August 2011 - 12:40 PM.
#7 AliM
AliM
    insert humour here
  • 9,146 posts
Posted 09 August 2011 - 12:42 PM
An hour per hub tops. The pro's will have air impact wrenches which makes things massively easier.
OK, thanks Steve.
I'll have to try it myself, but if it looks like it's going to be a bugger i'll take it to a garage.
Cheers
#8 The Batman
Posted 09 August 2011 - 12:52 PM
I agree only use 6 sided sockets There is a bodge you can do though :ninja: unless you want to make it all proper thumbsup
#9 AliM
AliM
    insert humour here
  • 9,146 posts
Posted 09 August 2011 - 12:58 PM
I'm sick of my car being one big bodge. If you mean solder the wires back onto the hub, i did that last time and it lasted 10 minutes. I've bought the new hub now and all the stuff for my ABS cut off switch, so will just change it.
#10 The Batman
Posted 09 August 2011 - 12:59 PM
Sort off... Just solder new Cables to another hubs abs sensor ;)
#11 Nikov
Nikov
  • 723 posts
Posted 09 August 2011 - 01:14 PM
All my hubs came off dead easy. Seems I was lucky, hope you are too. Good luck.
#12 AliM
AliM
    insert humour here
  • 9,146 posts
Posted 09 August 2011 - 04:49 PM
I've got more chance of changing the hub myself than doing any sort of wiring wizardry!
#13 drpau
drpau
  • 1,899 posts
Posted 09 August 2011 - 08:44 PM
Are you doing the rears? Best to use a hub puller to get it off the spline of the driveshaft.. I got one from Halfords (was only 4 bolt hub style but managed to make it work).. Was a bitch of a job getting those 3 hub bolts off. There was some effin and jeffin.....
#14 AliM
AliM
    insert humour here
  • 9,146 posts
Posted 09 August 2011 - 08:57 PM
I'm just doing the OSF Paul, I imagine the air will be blue :lol:
would the puller thingymebob work on the front?
#15 turbobob
turbobob
    2/3rds of a Queen
  • 13,833 posts
    Photography
    CARS!!
    Travelling
Posted 09 August 2011 - 08:58 PM
If you aren't sorted when I get back from holiday, I'd be happy to take a look at soldering the wires.
Edited by turbobob, 09 August 2011 - 08:59 PM.
#16 AliM
AliM
    insert humour here
  • 9,146 posts
Posted 09 August 2011 - 09:08 PM
Thanks Bob, but it's been done before and it doesn't hold because they broke too close to the hub. Have bought the replacement parts so will give it a crack :)
#17 turbobob
turbobob
    2/3rds of a Queen
  • 13,833 posts
    Photography
    CARS!!
    Travelling
Posted 09 August 2011 - 09:17 PM
Well the offer stands as its what I do for a living ;)
But good luck with changing it chinky chinky
#18 Anarchy
Anarchy
  • 2,237 posts
Posted 09 August 2011 - 09:22 PM
I had a go on my driveway, could not remove the three bolts so ended up splitting it off with the whole hub carrier casting thingy whatever still attached ie. at the hub carrier bolts/ball joint and took the whole assembly to a place with an air impact wrench. The discs were quite badly rusted on too :( Good luck.
#19 14500rpm
14500rpm
  • 381 posts
  • Interests:Boobs, Cars. Motorcycles.
Posted 10 August 2011 - 01:17 PM
Do you need to use new hub nuts (to connect to the driveshaft) when you put it back together?
#20 Pidgeon
Pidgeon
  • 5,254 posts
Posted 10 August 2011 - 01:28 PM
Ali, you don't need a puller on the front (no driveshaft to push out), 14,500, all the ones I have bought have been supplied with a different replacement Torx headed nuts, I reused originals
