Idiots Guide To Hub Replacement?
21 replies to this topic
#21 drpau
drpau
  • 1,899 posts
Posted 10 August 2011 - 07:00 PM
Ali, you don't need a puller on the front (no driveshaft to push out),
14,500, all the ones I have bought have been supplied with a different replacement Torx headed nuts, I reused originals
:yeahthat: and the torx head nuts were a lot longer than the standard ones already on the VX...
Use loads of plus gas (good lube) and make sure youve eaten your spinach..
#22 JG
JG
  • 13,617 posts
Posted 10 August 2011 - 08:51 PM
Ali, you're near london now aren't you? Bring it to me if you like, i'll do it for you. I have an air impact hammer and that sorts the hub bolts out.
