M32 box - Astra VXR (for the vxT)
Europa driveshafts - lotus dealer
New front mount - No, use the vx220 front mount
Passenger gearbox Mount and astra adaptor (usually comes on the vxr box, but only £25)
Rear gearbox mount
Heavy old dual mass flywheel
alter the gear cables - only slightly adjust one
alter the gear shifter - reverse gate required
is there a lightweight flywheel for this conversion - yes
what clutch do I need - standard vxr or Helix
Anything else I've missed? - lengthen reversing light switch wiring loom, modify clutch pipe
Thank you sir, just what I needed, now the search for rocking horse dung (at a reasonable price) commences
