Weight Reduction
27 replies to this topic
#1 darronwall
darronwall
  • 2,706 posts
Posted 31 October 2011 - 09:34 PM
looking for a bit of a guide to removing any unwanted items from the car to reduce weight,as all the removable bodywork is coming off the car its an ideal time to remove any bits it doesnt need as its a track only car cheers darron
#2 Winstar
Winstar
  • 4,264 posts
Posted 31 October 2011 - 09:52 PM
quite old but a start
I've found the list of removed/added parts with the relative weights:
these are my removed parts on solo-track-days: (no pax)
pax seat 8,7 kg
pax belt 1,3
insulation behind seats 3,5
side mirrors+foglights 2,7
speakers+stock airbox 3,5
rims+tires (replaced by OZ+yoko) 12
backbox (komo-tec) 6,0
exhaust manifold 1,7
kat-removed 4,1
soft-top 4,7
metal+plastic headrests 2,2
two undertrays 6,0
tank-cover tray 2,0
footrest+carpet 1,4
race battery 6,0
heater unit 3,5
rear plate holder 0,3
front logo 0,3
water resevoir bracket 0,3
engine lifting supports 0,4
footwell divider 0,7
braided brake lines 0,3
drilled discs (front only)0,4
engine/cockpit insulator 1,1
fuel vapours canisters 1,9
ali tank 6,0
trunk lid 6,7
TOTAL: 88KG
added parts:
cooling brake ducts 1,2
fake-carbon mirrors 0.2
kat-bypass hose: 1,2
CDA 1,0
harness bar 3,0
4-points OMP harnesses 1,0
lexan trunk 1,1
front splitters 0,2
ADDED TOTAL: 9 kg
CURRENT SAVING: 79KG
there might an extra 1,5kg from the airbag IF I did not added to the speakers combo. (will verify today... :rolleyes:)
still to add: polycarbonate windows
race clutch+flywheel+pistons+rods
+the weight of the Delta kompressor
will also arrive (sometime this year) carbonfiber front trunk (big saving there!)
carbonfiber 3rd stop rollbar cover
#3 Corey
Corey
  • 339 posts
Posted 31 October 2011 - 09:55 PM
Could start off with the heater kit and plates behind seat heads, and perhaps the rear shelving/firewall cover and insulation, I reckon those together are pushing 15kg, maybe a bit under. Im a bit out of knowledge on this part tho, try messaging forum member 'Nev', he's got some good knowledge around this area, but I'm sure lots of others have too :)
#4 Corey
Corey
  • 339 posts
Posted 31 October 2011 - 09:57 PM
Ah, well there is your answer :lol: I was a bit late :P
#5 Delta Deano
Delta Deano
  • 461 posts
  • Interests:Motors, Beer, And more Beer
Posted 31 October 2011 - 10:02 PM
The headrest's and plates have allready gone also the plastic shelf behind seats removed and speakers & stereo boot lining. centre console gone.
#6 darronwall
darronwall
  • 2,706 posts
already removed any interior bits we dont need,and plan to remove all heater parts and poss rear screen winstars post above mentions the undertrays,has anyone run without them?? i am thinking that if the car was fitted witha functioning splitter and some side skirts it would create negative pressure under the car and thus draw air thru the engine bay reducing heat??
#7 darronwall
darronwall
  • 2,706 posts
Posted 31 October 2011 - 10:03 PM
could just go for a big sh** and lay off the ale for a week eh?
#8 jules_s
jules_s
  • 15,275 posts
  • Interests:Plane spotting
Posted 31 October 2011 - 10:04 PM
Impressive searching by Winstar given ricky2772 profile shows no topics/posts (I looked) Strange how google brings them all up :angry2:
#9 2.2_na
2.2_na
    No Compromise
  • 6,323 posts
Has anyone worked out what difference the weight saving will make to the performance? For example: Each saving of 10kg will result in a 0 - 60mph saving of ....seconds?
#10 Delta Deano
Delta Deano
  • 461 posts
Posted 31 October 2011 - 10:05 PM
No can do :lol:
#11 GeorgeBC
GeorgeBC
    Needs a cheaper hobby
  • 3,138 posts
Posted 31 October 2011 - 10:26 PM
Get a hair cut and leave your wallet in the van, theres a big weight saving. Then look at pro alloy fuel tank. Remove headlights and fit blanking plates remove dashboard, perspex windows/no windows? Remove alarm and locks.
#12 davemate
davemate
    Harrop!!!
  • 3,228 posts
  • Interests:Provoking Badgers
Posted 01 November 2011 - 01:03 AM
Plastic cam cover and lightened flywheel. Swap to lighter lotus hubs and then lotus oz wheels
#13 GeorgeBC
GeorgeBC
  • 3,138 posts
Posted 01 November 2011 - 06:19 AM
Its a turbo so already has a plastic cover. He already has a lightened flywheel fitted. The wheels are worth considering although expensive as he runs heavy speedlines at the mo
#14 Ormes
Ormes
  • 4,612 posts
Posted 01 November 2011 - 08:49 AM
From Nev's Blog http://sites.google....6-weight-saving
#15 Glambee
Glambee
  • 104 posts
One very useful site: http://myelise.fr/prepa/visiteur.html It's Chris' site, and even if it is in French, there are a lot of pics to help you find ideas
#16 Ormes
Ormes
  • 4,612 posts
Posted 01 November 2011 - 09:07 AM
Wow that's attention to detail thumbsup
#17 14500rpm
14500rpm
  • 381 posts
  • Interests:Boobs, Cars. Motorcycles.
Posted 01 November 2011 - 10:11 AM
Elise Parts aluminium centered disc brakes would probably save a bit too, and saving weight off bits that go up and down and round and round is worth more than normal weight saving.
#18 efrenlotus
efrenlotus
  • 19 posts
Posted 01 November 2011 - 12:21 PM
In the case of vx220 turbo , this is the bible: http://www.garage111...1d66e98b2166288
#19 Glambee
Glambee
  • 104 posts
Posted 01 November 2011 - 01:28 PM
It's the same author ;)
Another crazy guy about weight saving is Gilles (Rugissante). A very complete topic there:
http://www.myspeedst...opic.php?t=5572
#20 smiley
Posted 01 November 2011 - 07:48 PM
That car is for sale. Gilles is moving up, but will not tell us to what. :closedeyes:
