Hub Carrier Bolts
Posted 31 October 2011 - 09:58 PM
When I bought the car it came with a pack of unfitted Brand new Hub Carrier Bolts 12.9
Am I right in thinking these are NOT the uprated ones?
So these are the ones I want? (10.9)
http://www.mangomoto...p?id_product=15
If so.....
The I was told that they fit where number 5 goes in this diagram? But that's 1 bolt, not 4?
Please excuse my ignorance.
(Actually I don't care if you don't and take the p*ss) as long as I can work out what to do.)
Posted 31 October 2011 - 10:03 PM
Posted 31 October 2011 - 10:06 PM
It's two bolts per corner. Diagram just shows one but shows both holes.
Ahh right
Told you I was ignorant.
Thanks for that though.
Presume when I remove the fronts they will be different lengths already so obvious where they both go if they are in the same positions.
Anything else worth changing before fitting sticky tyes?
Posted 31 October 2011 - 10:07 PM
Edited by SteveA, 31 October 2011 - 10:07 PM.
Posted 31 October 2011 - 10:12 PM
Posted 31 October 2011 - 10:20 PM
Posted 31 October 2011 - 10:22 PM
10.9 grade are the Lotus Motorsport recommended.
Ye I've just read quite a long old thread talking through the differences. Have now ordered a set of 10.9s
So as it's going to involve having geo reset I presume, is there anything else worth changing that semi slicks will show up weakness in>?
Posted 31 October 2011 - 10:27 PM
Posted 31 October 2011 - 10:32 PM
As per Lotus service bulletin:-does anyone know what tightening torque these need ?
- Earlier type 8.8 grade bolts should be tightened to 45 Nm; Later 10.9 grade bolts to 68 Nm. The bolt grade is stamped around the head of the bolt.
- The thread of both bolt types should first be thoroughly cleaned before treating with Permabond A130 (A912E7033V).
Posted 31 October 2011 - 10:35 PM
No need for a new geo, if you remove and replace one bolt at a time before moving onto the next one.
cool
Just done some reading on rear toe links. These are a geo job though aren't they?
Elise parts kit might be affordable, nitron looks pretty and yet unaffordable.
Cool all food for thought. Going to stick to road tyres for the next few trackdays till I learn a bit more. Winter is a good time to get some of these little bits done though.
Posted 31 October 2011 - 10:39 PM
Yes. Although as it's only toe that is likely affected, you could get away with a "tracking" session at most garages - if you know the value it is currently set to, or that you want. May still be worth a proper geo at a specialist, if it hasn't been done for a while or if you want to change camber etc (most tyre places pale when you mention removing shims etc).Just done some reading on rear toe links. These are a geo job though aren't they?
Posted 31 October 2011 - 10:49 PM
Posted 31 October 2011 - 11:05 PM
Edited by ghand, 31 October 2011 - 11:10 PM.
Posted 01 November 2011 - 09:56 AM
Posted 01 November 2011 - 10:11 AM
I would deffinitely recomend tapping the holes. I found mine weren't tapped out right down and I was bottoming out with new HCB's.
Posted 01 November 2011 - 11:44 AM
