Mini VX Overhaul
Posted 06 November 2011 - 04:57 PM
Where to begin? Right. Some time in May this year my oil cooler went pop, I sourced a second hand one from Liz, got my self all mucky and fixed it and got my self motoring again...
...until the day after the final round of the BTCC, 17th October. I went to work and when I went down to the car park to go home I was greeted by this now-familiar-to-me sight:
Oil pee
Expansion tank filled with chocolate
I was dis-pleased to say the least.
I decided right there and then that there must be an underlying issue and I needed to take the car off the road to do some investigation.
As luck would have it a mate a work was selling his old Ford Ka.......now I know what your thinking ITS A KA but hear me out!
It's an X-reg, 1.3 Lux in dark blue, 49,000miles, cream leather, AC, heated front and rear screens, remote CL and boot pop, alloys, Tax until MAY 2012, MOT until Dec 22nd. It has a patch of rust on the A pillar and few dents but other than it was in perfect working order. So I bought it! How much did I pay for this little gem I hear you say.....TWO HUNDRED AND FIFTY POUNDS!
Yup.....bargain tastic! So now I was motoring again and could tend to the poorly VX in a timely fashion
Updates to follow......
Posted 06 November 2011 - 05:00 PM
Pics of the Ka:
Posted 06 November 2011 - 05:08 PM
T'is done.Can mod change the title to say 'Mini' instead of 'Mine'? Ta!
I immediately placed an order with JG (http://www.mangomotorsport.co.uk/) for all the complete set of bolts to replace just about every nut and bolt on the car
Next I got on with ordering a decent dremel and a pop up gazebo as there is no way I could fit the car in the garage as it full of
My second stroke of luck after the Ka find then came along: GTVX220 put his for sale thread up which contained an oil cooler and much needed drivers door hinge, as my door sags about half an inch when you open it.
So I snapped them up.
I then got on with getting the car prepared:
Whilst waiting for parts to arrive I thought I'd get on with fixing other bits, the heater for example. So I whipped it out. So glad my battery has a handle!!!!
Posted 06 November 2011 - 05:09 PM
T'is done.
Posted 06 November 2011 - 05:12 PM
I've cleaned all the bits up and I'm currently soaking the rusty bits in Bilt Hambers Deox-C. Once they are rust free I will spray them and reseal the heater.
Posted 06 November 2011 - 05:13 PM
During:
After the first 'bath':
Posted 06 November 2011 - 05:15 PM
I would guess that your oil pressure relief valve is stuck shut on your oil pump, thus causing two oil cooler failures, best add that to the list of things to fix
Ok, is this an easy part to check/replace?
Posted 06 November 2011 - 05:21 PM
Posted 06 November 2011 - 05:23 PM
I had my penetrating oil and dremel at the ready, the playlist on my iPhone set and the instructions printed that were kindly sent to me by Winstar. I was prepared for day of hell.
I started at 10.20am on Saturday and by 1pm when I got the 'dinners 5 mins away' shout, the last bolt came out
I had a few surprises on the way mind....... photos will show you what I mean:
Seats out, speakers out, plastic back off.....what the hell! no wonder I had a few rattles...look how many nuts and washers I found
ALL of these were loose on the rear shelf:
A bit worrying as I'm not sure if they should be on the car! nothing seems to missing apart from a few washers I think
Next I got with removing the roll bar cover and I found a PEN under it...and it still worked!
Posted 06 November 2011 - 05:26 PM
Posted 06 November 2011 - 05:27 PM
Broken exhaust mount:
Posted 06 November 2011 - 05:30 PM
Hmm 'interesting' door cards!
They're going! Don't worry
I've got some paint from paints4u and will be matching them to the body colour as that's what they are underneath, but it was soo badly painted that it started to crack and peel.
That was a £3 quick fix during a top dear episode!
Posted 06 November 2011 - 05:50 PM
The exhaust came off with no trouble and then I saw the reason for my cold start ticking, one broken stud:
See my other thread about my little hiccup with drill bits on getting this stud out
All the other studs came out with no trouble. I have new studs, nuts and a new gasket (I just have to find them!) ready to go
The manifold is crack free thankfully which was pleasing.
Started draining sludge and fluids and removing the offending oil cooler:
Lovely mess to clear up:
With Saturday out the way I'd got a lot of stuff removed. I was a happy and but tired chappy. Nipped over to a mates for some fireworks and bonfire, had obligatory toasted marshmallows
Posted 06 November 2011 - 05:53 PM
Hand built in EnglandALL of these were loose on the rear shelf:
Good read
Posted 06 November 2011 - 05:56 PM
oil pressure relief valve is mounted on the outside of the oil pump, I think it has an 8mm or 10mm hex allen key plug on the oil pump casing, it's located below the water pump near the crank pulley.
remove the plug and then try and get the relief valve out, it may be seized, otherwise get a replacement oil pump
Fantastic! Is there anything you don't know when it comes to the VX220?
On a side note: As I've been removing bits and bobs, I've been labelling and bagging all the nuts and bolts until I get a nice parcel from JG
Posted 06 November 2011 - 06:16 PM
I was able to put my rear poly engine mount bush in; with the clam and exhaust on I bent an extension bar and still didn't get the mount off....It took less than half and hour with all the other bits out the way.
Then I fitted my M-tech short shifter, again, with the clam on the is a huge PITA to do!
Following Mark Verbooms guide, I had the pin out in 6 hits with a punch and a club hammer.
Then covered up all the important bits and got the APC and Degreaser out and gave everything a basic clean...pics tomorrow
So that's where I'm at now.
Edited by DarrylB, 06 November 2011 - 06:17 PM.
Posted 06 November 2011 - 06:25 PM
Posted 06 November 2011 - 06:42 PM
Here's my list of jobs left to do now that I have a daily drive and the car in bits
Repaint the door cards and dash plates
Repaint the rear spoiler due to flaky lacquer
Get the passenger door bubbles filled and door painted
Replace drooping drivers door hinge
Re-seal heater matrix and refit
Replace the aerial base as the rubber has perished
Paint callipers and hubs
Repair worn seat bolster
Fix rocking seat runner and repaint them
Fit new thermostat
Overhaul the exhaust with all new gaskets and nuts and bolts
Drill out broken stud
That's all I can think of for now
Cheers to everyone that has helped so far! I'm sure I'll have more questions as time goes on
Love this place!
Edited by DarrylB, 06 November 2011 - 06:43 PM.
