Ebay Wheel Bearings
Posted 19 December 2011 - 11:17 PM
Posted 19 December 2011 - 11:30 PM
Ended up getting a set from VauxCentre in Romford for about £60 each which fitted fine and have been fine for the last couple of years.
Posted 20 December 2011 - 01:08 AM
used them for odds and sods over the years, Local to Lizzie (not really romfored, bit out the way towards gallios corner) If you need anything picking up from there let me know
Posted 20 December 2011 - 07:45 AM
Posted 20 December 2011 - 08:13 AM
Posted 20 December 2011 - 08:25 AM
Posted 20 December 2011 - 08:39 AM
Posted 20 December 2011 - 09:13 AM
Has anybody tried the eBay wheel bearings out? Any good reports or horror stories. Need a pair and I am frightened what Vauxhall will charge.
Autovaux an option?
This for your car? You're thinking of spending a grand on a weekend, yet would risk that to save £50 on a bearing? They're performance and safety critical items, buy the best.
(That said, I know SKF are BMW OE, so as long as I can open the box and confirm they are SKF bearings in the hub, I will buy from anywhere. I guess it is knowing you have bought quality. SKF bearings will last a season. I've seen spurious ones fail catastrophically after one session.)
Posted 20 December 2011 - 10:17 AM
Posted 20 December 2011 - 10:29 AM
Posted 20 December 2011 - 10:32 AM
I could do with one as an abs sensor wire as broken right next to the hub, I tries melting the plastic coating to connect the wire again but didn't work fo me
You can prise the sensor off an old hub then replace yours. If you do this any old veccy hub would do.
Posted 20 December 2011 - 11:19 AM
Edited by vocky, 20 December 2011 - 11:19 AM.
Posted 20 December 2011 - 11:22 AM
I have a used hub here Nick, you are welcome to it.
Posted 20 December 2011 - 12:57 PM
Great do you know if it comes off easy?
Thanks Mike, yes please
Posted 20 December 2011 - 12:59 PM
Posted 20 December 2011 - 01:06 PM
Posted 20 December 2011 - 01:12 PM
Posted 20 December 2011 - 02:24 PM
Posted 20 December 2011 - 03:11 PM
Posted 20 December 2011 - 11:50 PM
The fun bit. The rear is complicated by needing to knock the driveshaft out.
