Engine Temp 130
Posted 04 January 2012 - 05:59 PM
Posted 04 January 2012 - 06:17 PM
Edited by VXBONE, 04 January 2012 - 06:18 PM.
Posted 04 January 2012 - 07:52 PM
Posted 05 January 2012 - 01:31 PM
Posted 05 January 2012 - 01:33 PM
Posted 05 January 2012 - 01:37 PM
Posted 05 January 2012 - 01:39 PM
Posted 05 January 2012 - 03:07 PM
Posted 05 January 2012 - 03:13 PM
Posted 05 January 2012 - 03:36 PM
Posted 05 January 2012 - 03:42 PM
I ment a quick way to find out if this is the problem, not to run it forever like it.errr.... and have the car permanently running too cold...there is an optimum operating range. Having the termostat open all the time means it will be below is, possibly meaning it stays in choke territory, furring up injectors, pistons and causing all sorts of other mayhem. Replace the thermostat and see if that helps.
Posted 05 January 2012 - 04:30 PM
Sounds like it could also be the water pump, but check the thermostat first as it's alot easier to get to!
If its the water pump the rad wont get warm/hot and the heater matrix wont be supplyed so its fairly easy to check.
Posted 05 January 2012 - 04:37 PM
Sounds like that's well into potential head damage territory.
I wouldn't be leaving the engine running at 120 / 130 C.
Posted 05 January 2012 - 04:47 PM
there will be a small convection driven flow through the circuit due to the diference in hight between the rad and engine
Posted 05 January 2012 - 04:53 PM
Posted 05 January 2012 - 04:55 PM
Tru, but it wil take ages. engine will long overheat before rad gets hot.
I'm placing my money on the thermostat, as its cheap and easy to replace (then the pump)
Posted 05 January 2012 - 05:29 PM
Posted 05 January 2012 - 07:59 PM
Posted 05 January 2012 - 08:02 PM
Posted 06 January 2012 - 03:32 PM
the sencer might be working but if i'm not mistaken the way it opens is by a heat sensitive spring, so that bit could have failed or broken?
i have one from a GM engine in the shed, i'll take some pics and post tonight if you like?
