Wont Start After Running Out Of Fuel...
39 replies to this topic
#1 MEAGY
MEAGY
  • 1,374 posts
Posted 16 January 2012 - 09:18 PM
Its been sat in my mates garage for a couple of months where by moving it in oit for other work it ran out of petrol & now after refilling it wont start again!! It has a couple of fault codes which are.. Injector circuit open cylinder 1 (p0201) Injector circuit open cylinder 3 (p0203) Injector circuit open cylinder 4 (p0204) Injector circuit open cylinder 2 (p0202) Evaporative emission purge control valve circuit (p0443) o2 sensor heater circuit (bank 1,sensor 1) (p0135) o2 sensor heater circuit (bank 1,sensor 2) (p0141) Could all this be caused by sucking up poo from the bottom of the tank & blocking the pump or the filter? There is no fuel being pumped as i have disconnected the fuel line by the expansion tank with the ignition turned, i also dont think i can here the fuel pump at all. Help! cheers Liam
#2 davemate
davemate
    Harrop!!!
  • 3,228 posts
  • Interests:Provoking Badgers
Posted 17 January 2012 - 11:56 AM
have you tried pressing the cut off switch in the boot to see if that makes a difference?
#3 vocky
Posted 17 January 2012 - 12:12 PM
relay K18 (in boot) or fuse FL4 (under windscreen), these power all the above circuits :sleep:
#4 LY_Scott
LY_Scott
    Formerly LY055SCO
  • 9,221 posts
Posted 17 January 2012 - 12:20 PM
Also, I had a gotcha after running out of fuel. Filled up from jerry can but wouldnt start, commenceth flap attack and much confusion.......second jerry can full eventuall put in. Fired first time. I assume your mates garage is level. But assume its something simple first.
#5 MEAGY
MEAGY
  • 1,374 posts
Posted 18 January 2012 - 07:19 PM
Yes i tried the fuel cut off & its had 2 cans of fuel! I will try the relay & fuse next cheers Vocky!
#6 MEAGY
MEAGY
  • 1,374 posts
Posted 18 January 2012 - 09:45 PM
Which relay is K18?
#7 techieboy
Posted 18 January 2012 - 09:46 PM
Brown relay in the boot.
#8 MEAGY
MEAGY
  • 1,374 posts
Posted 26 February 2012 - 11:15 AM
After swapping the relay with one from the front it fired up, run it a few times since and all fine. But problem has come back so did the relay swap again but still wont fire up! Anything else it could be?
#9 The Batman
Posted 26 February 2012 - 11:21 AM
can you hear the fuel pump priming when you turn ignition on? when you go to start it does it just click etc?
#10 MEAGY
MEAGY
  • 1,374 posts
Posted 26 February 2012 - 11:28 AM
yeh i can hear the pump, no its turning just no fire!
#11 The Batman
Posted 26 February 2012 - 11:34 AM
So you probably have fuel just no spark? Worth checking all earthing points on the cam cover,ay be get some of those spark plug lights that go between plugs and coil pack only about 15-20£ from halfords
#12 MEAGY
MEAGY
  • 1,374 posts
Posted 26 February 2012 - 11:44 AM
it say `injector circuit open cylinder 1,2,3,4
#13 The Batman
Posted 26 February 2012 - 11:46 AM
hmmm.... tried pressing the fuel pump cut off switch?
#14 MEAGY
MEAGY
  • 1,374 posts
Posted 26 February 2012 - 11:12 PM
Yep tried that!
#15 Sutol
Sutol
    Well it's nearly a Lotus
  • 8,122 posts
Posted 26 February 2012 - 11:45 PM
do you get fuel to the rail? I believe there is a valve which you can open on the rail which will give you an idea if pressure is there. Opening this valve will bleed any air in the system too.
#16 TheRealVXed
TheRealVXed
    Sidekick
  • 5,975 posts
Posted 27 February 2012 - 03:59 PM
You don't need to bleed a fuel system... If there is pressure fuel will squirt out. Use a rag over the valve to stop it going everywhere... You could have a blocked filter though. Try putting a full tank in too, as it may be sucking on empty again...
#17 Sutol
Sutol
  • 8,122 posts
Posted 27 February 2012 - 05:27 PM
What's that little bleed valve thingy for then?
#18 vocky
Posted 27 February 2012 - 05:45 PM
did you use a grey relay instead of the brown one ?
if yes then thats probably the problem, they have a different internal circuit arrangement
#19 MEAGY
MEAGY
  • 1,374 posts
Posted 27 February 2012 - 09:12 PM
I dout using the bleed valve will do anything. Vocky, i replaced the grey relay with a grey one with the same part number. I dont or didnt have any brown relays in the boot, just brown sticker on one of the relay block connector?
#20 TheRealVXed
TheRealVXed
    Sidekick
  • 5,975 posts
Posted 28 February 2012 - 08:57 AM
It's a pressure release value to de-pressurise the system when you need to take the fuel lines off for example.
