Wont Start After Running Out Of Fuel...
#21
Posted 28 February 2012 - 09:14 AM
#22
Posted 13 March 2012 - 08:40 PM
#23
Posted 19 March 2012 - 08:31 PM
#24
Posted 19 March 2012 - 08:55 PM
#25
Posted 19 March 2012 - 09:13 PM
#26
Posted 19 March 2012 - 09:24 PM
#27
Posted 19 March 2012 - 09:49 PM
#28
Posted 19 March 2012 - 10:25 PM
#29
Posted 19 March 2012 - 10:59 PM
http://www.speedster...Fuel%20pump.pdf
(switch S94 & pump M21)
Not sure if both colors are violet, but 12v on pin 1 of the connector should do it.
If that does not help (and you really have enough fuel in the tank) your pump is knackered.
Edited by Exmantaa, 19 March 2012 - 11:00 PM.
#30
Posted 24 March 2012 - 07:50 AM
#31
Posted 24 March 2012 - 04:03 PM
#32
Posted 24 March 2012 - 08:26 PM
#33
Posted 24 March 2012 - 09:28 PM
#34
Posted 27 March 2012 - 08:30 PM
#35
Posted 03 April 2012 - 09:35 PM
#36
Posted 04 April 2012 - 12:00 AM
ive taken fuel lines off & turned the ignition but nothing comes out!
Something is wrong with fuel system then!
#37
Posted 05 April 2012 - 07:41 PM
#38
Posted 05 April 2012 - 08:12 PM
#39
Posted 05 April 2012 - 09:49 PM
Spoke to an automotive electrian today & he reckons if its not a visable break in the wire its the ecu packed up! CAn the stage 2 data be saved from the old ecu & put onto a new one if it is at fault?
This thread is taking forever:
- Check your ecu for any fault codes => immobiliser/key fault code and your car will never start. (buy/borrow a reader. Reprogam immo with Opcom)
- Check if your fuelpump runs and gives pressure => fab/buy/borrow a fuel pressure gauge and check your base pressure of 3.8 bar. Maybe remove complete fuelrail with injectors and see (on a rag f.i.) if they spray good and strong.
Check ignition for sparks. Not sure how to easily check this on the Z22 coilpack and if the plugs work when removed from the cylinders (compression sense stuff) Borrow another pack and exchange. (capacitor still earthed to ground?)
- Check you engine for mechanical malfiunctions, like a simp le compression check.
#40
Posted 08 April 2012 - 08:14 AM
