It all started on th 15th of July last year when I bought an Opel Speedster 2.2 SC from 2003.
The car has the color British Racing Green, and had been rolling just less than 40.000 km (about 25.000 miles?).
I'm the third owner of the car (original buyer is from Germany, and imported to Sweden back in 2008).
The following was done on the car when I bought it:
- SC stage 2 conversion done by Hitec (racecams, ported head...).
- Full alu radiator.
- Komo-Tec sportcat.
- Sandtler 4-point harness on the drivers side (belt slots will be made).
- OZ Supertourismo WRC-rims with Toyo R888 (205/40-17 front & 235/40-17 rear).
- ATE Power Disks.
- Flexible steel break lines.
- EBC Yellow Stuff break pads.
- JRZ racingdampers.
- Vmax display (with shiftlight).
- Lightweight battery.
- Fire extinguisher.
- 340R Track alignment.
- Pro-Alloy tank (48 liters). - Done. Just to check that there's no leakage...
Also fixed the hole at the fuel pump (with JG's version as model)... Only need to do a cover now... - Powerflex engine mounts. - Done.
- Short-shift (from VX-Performance). - Done.
- Short ratio steering rack (2.50) (from VX-Performance). - Have but not mounted.
New track rod ends ordered. - Steering joints and rod. - Ordered.
- TAT short diffusor with rounded cutting. - Have but not mounted.
- DLC front and rear racing towing eyes. - Have but not mounted.
- Elise Parts removable steering wheel kit. - Ordered.
Thinking about using OMP Superquadro steering wheel... - (Oil and filter change. - Done.)
