Posted 10 February 2012 - 10:39 PM
Posted 10 February 2012 - 10:41 PM
pffftt thin air tends to be lighter than most things
Helium would be better.
Posted 10 February 2012 - 10:42 PM
@ techie. If you will buy from barry boys.
Very butch looking, a later model maybe?
Posted 10 February 2012 - 10:44 PM
Posted 10 February 2012 - 10:47 PM
Posted 10 February 2012 - 10:52 PM
Posted 10 February 2012 - 10:53 PM
Posted 13 February 2012 - 01:43 PM
If you remove this pressure area then a front splitter would become less effective. Not a bad thing on a standard car but not so good for anyone with a big wing?? Although they have a small effect would canards be good here? Lifts the air up on the side of the flat front area??
The more dense the lines the higher the pressure.
Reminds me of Pasta Verde.
I'm no aerodynamicist, and anyway the louvres on mine were just for show and didn't have corresponding holes in the wheel arch (as someone who always had the roof off, I didn't fancy getting wet every time I drove through a puddle). But if it's any use to anyone, I can say that when the radiator got properly hot (i.e. stuck in stationary traffic for some time) the heat would be streaming out of the louvres after it was parked up -- if anything, more than out of the bonnet mesh.
As such, I would presume that at speed, there is considerable additional airflow entering through the front grill, passing over the radiator, and coming out of the louvres (as well as out of the bonnet mesh). This might mess up any calculations, unless you are going to duct the air from the wheel arch liner hole to the louvres.
Ahh ok so it can help with cooling then too!! I'm liking this more and more
Posted 13 February 2012 - 02:13 PM
