Hi guys. I've been leaving my VX on charge (Ctek XS3600) whilst not in use, usually for one night every few days, to make sure the battery is topped up. However, after a day or two's use I'm noticing that the car will struggle to start as though it hasn't much power, but will then fire up. I use it to commute and that is enough distance that it should be charging up on the alternator with no problems. What makes me think the alternator may be an issue is a post by DarrylB in a separate thread:
Hmmm I'd start by checking the alternator is supplying the right voltage. I had an alternator fail on my old Astra and it was dishing out 19.8v and plenty of smoke! Caused the power steering to fail which was fun with 5 in the car.
The reason I think this is that mine is giving off white smoke out of the rear drivers side boot vent every now and then. Any thoughts on this or tips on how to test the alternator?
Edited by VXTyrant, 09 March 2012 - 10:08 PM.
