Vx220 Turbo Gearbox
Posted 30 March 2012 - 02:37 PM
Posted 30 March 2012 - 02:38 PM
Posted 30 March 2012 - 02:39 PM
Posted 30 March 2012 - 02:48 PM
Posted 30 March 2012 - 02:52 PM
NA and Turbo gearboxes are virtually the same, the only external difference (although a major one) is that they use differenet, but interchangable bell-housing patterns, and internally, a different final drive ratio.
Some versions of the F23 fitted to the Vectra have a different outer casing, and therefore do not have the 3-bolt mounting point on the top of the gearbox, so be worth sticking to the correct alpha code (as advised), or posting pics up here for ID.
See link below for info on codes / ratios etc.
http://www.opel-info...triebe/f23.html
Edited by Rosssco, 30 March 2012 - 02:55 PM.
Posted 30 March 2012 - 02:57 PM
http://www.ebay.co.u...6f#ht_500wt_949
Posted 30 March 2012 - 03:00 PM
Posted 30 March 2012 - 03:05 PM
Posted 30 March 2012 - 03:11 PM
Posted 30 March 2012 - 03:13 PM
Posted 30 March 2012 - 03:14 PM
this is the same guy I bought mine off and he is honest to deal with. But tell him you want an "AF" ident code.
Posted 30 March 2012 - 03:16 PM
Or this one?
http://www.ebay.co.u...e#ht_1012wt_932
Im confused
Its the right fitment, but wrong final drive ratio. You want one with a 3.63:1 ratio.
Posted 30 March 2012 - 03:21 PM
Posted 30 March 2012 - 03:25 PM
Anyone know the difference between the AF and TR, Ratio?
I think they are the same gearbox, just different Alpha codes (perhaps a production coding thing?). As per the attached link, both TR and AF are listed as Astra G Z20LET.
Edited by Rosssco, 30 March 2012 - 03:26 PM.
Posted 30 March 2012 - 03:26 PM
Posted 30 March 2012 - 03:28 PM
the selector shaft part is different, in terms of the breather, on the TF its moved
I bow down to superior knowledge, didn't know that..
Posted 30 March 2012 - 03:33 PM
Posted 30 March 2012 - 03:36 PM
