Vx220 Turbo Gearbox
22 replies to this topic
#21 TurboTurkey
TurboTurkey
  • 220 posts
Posted 24 June 2012 - 04:39 PM
Hi all posters. Just reading this thread. Can anyone confirm that an NA 2.2 'box will fit no problem onto a turbo, with just a swap of bell housing? Is it able to stand up to the power of a modified car, or will there be problems? Assessing my options Cheers
#22 Nev
Posted 24 June 2012 - 06:22 PM
Here is some useful info on gearboxes/ratios/part numbers/doner cars/Id marks:
VECTRA GEARBOXES
4.17 RATIO 16LZ2,20NEJ,C20SEL,X20XVE 90578385 7 00 032 (IDENT SQ)
3.74 RATIO C20SEL,X20XEV,C22SEL 90578390 7 00 037 (IDENT SR)
3.95 RATIO C20SEL,X20XEV 90578386 7 00 033 (IDENT SS)
3.74 RATIO C20SEL,X20XEV, YL000001 - 90578390 7 00 037 (IDENT SR)
(FOR VEHICLES WITH C22SEL PLANT CODE L)
3.95 RATIO Z22SE 90578392 7 00 092 (IDENT ST)
3.84 RATIO X25XE,Y26SE 90578391 7 00 038 (IDENT SK)
3.84 RATIO X20DTL,X20DTH,Y20DTH 90578387 7 00 034 (IDENT SL)
3.95 RATIO X20DTL 90578388 7 00 035 (IDENT SM)
3.74 RATIO X20DTH,Y20DTH 90578389 7 00 036 (IDENT SP)
ASTRA G GEARBOXES
TRANSMISSION,ASSY.,3.95 RATIO X20XEV 90578397 7 00 051 (IDENT SC)
(EXCEPT OPC) (ALSO USE 90470781 7 24 632)
TRANSMISSION,ASSY.,3.95 RATIO X20XER 24426557 7 00 090 (IDENT TS)
(FOR OPC) (ALSO USE 90470781 7 24 632)
TRANSMISSION,ASSY.,3.74 RATIO X20XEV 90578400 7 00 052 (IDENT SH)
TRANSMISSION,ASSY., 4.17 RATIO X20XEV 5 DOOR HATCH 9126007 7 00 088 (IDENT SD)
(FOR SOUTH AFRICA) F48
TRANSMISSION,ASSY., 3.63 RATIO Z20LET COUPE F07 90424091 7 00 091 (IDENT TR)
(NLS.- USE 24451449 7 00 220 AND SUPPLY 90470781 7 24 632)
TRANSMISSION,ASSY., 3.63 RATIO Z20LET 24451449 7 00 220 (IDENT AF)
TRANSMISSION,ASSY., 3.95 RATIO Z20LET MONOCAB F75 24461371 7 00 175 (IDENT DZ)
TRANSMISSION,ASSY., 3.95 RATIO Z22SE HATCH,SALOON, 90578402 7 00 053 (IDENT SF)
(ALSO USE COUPE,ESTATE,VAN 90470781 7 24 632) F07,F08,F35,F48,F69,F70
TRANSMISSION,ASSY., 4.17 RATIO Z22SE MONOCAB F75 9126008 7 00 089 (IDENT SG)
TRANSMISSION,ASSY., 3.63 RATIO Y20DTH HATCH,SALOON, 9126006 7 00 050 (IDENT SB)
(ALSO USE 90470781 7 24 632) ESTATE,VAN F08,F35, F48,F69,F70
TRANSMISSION,ASSY., 3.84 RATIO X20DTL HATCH,SALOON, 90578398 7 00 029 (IDENT SA)
TRANSMISSION,ASSY., 4.17 RATIO X20DTL MONOCAB F75 90578403 7 00 030 (IDENT SJ)
TRANSMISSION,ASSY., 4.17 RATIO Y20DTH MONOCAB F75 90578403 7 00 030 (IDENT SJ)
TRANSMISSION,ASSY., 4.17 RATIO MONOCAB F75 24451455 7 00 844 (IDENT AR)
#23 vocky
Posted 24 June 2012 - 07:04 PM
the zafira GSI turbo DZ is a straight swap and comes with the 3.95 final drive ratio already fitted
