Wing Mirror Removal
Posted 13 May 2012 - 06:30 PM
Posted 13 May 2012 - 06:39 PM
Posted 13 May 2012 - 06:40 PM
Posted 13 May 2012 - 06:41 PM
Posted 13 May 2012 - 06:44 PM
Also have to remove the plastic cover as there is one hidden under there too
The triangle bit under the round stickers?
Posted 13 May 2012 - 06:56 PM
Posted 13 May 2012 - 07:18 PM
Yep it has a plastic bolt underneath it.
Are the stupid plastic gromet things holding the triangle on reuseable? How do you get them off?
If I drop the upper bolts when removing them then they fall into the door?
Anyone got a replacement mirror for sale?
Posted 13 May 2012 - 08:08 PM
Posted 13 May 2012 - 09:15 PM
Mirrors are the same as a Rover 100 / Metro.
. Ebay or maybe try ElizP if you really want one off a VX.
http://www.ebay.co.u...-All-Categories
Cheers Ken
How do I get the triangle bit off?
Posted 13 May 2012 - 09:17 PM
Cheers Ken
To be honest I'm not sure as I've never looked or even thought about looking. Sure someone will be along shortly though that knows.
Edited by Wolfstone, 13 May 2012 - 09:17 PM.
Posted 13 May 2012 - 09:19 PM
Posted 13 May 2012 - 09:24 PM
Posted 13 May 2012 - 10:25 PM
And if you do buy a rover 100 mirror, you might also need to add one of these as it doesn't look like the rover ones include them:
http://www.ebay.co.u...hash=item256ffc3eb6
You're getting as bad as Vocky, costing me money at every turn
Edited by Sticky, 13 May 2012 - 10:25 PM.
Posted 13 May 2012 - 10:33 PM
Edited by haggi961, 13 May 2012 - 10:34 PM.
Posted 13 May 2012 - 10:37 PM
Yeah all the stuff can be re-used. With the bolts my trick was to get all the 3 tools for the job that unscrew all the bolts. Then i unscrew each one leaving the bolt in the holes with the tool attached to it, when all 3 are undone tape the bolt thread up at the other end leaving the bolts in the door still. Handy if you have a couple pair of hands. If the bolt does fall out then just take the plastic cap of the end of the door and get a extenable magnet and have fun fishing it out.
Ok cheers for the tips
Go back a stage to the triangle bit. How did you remove the fixings. The central plastic spike is really tight
Posted 13 May 2012 - 10:41 PM
Posted 13 May 2012 - 10:43 PM
Posted 13 May 2012 - 10:46 PM
Posted 13 May 2012 - 10:48 PM
Only for 24 hours, after that it's a bit dodgy IMHO.
Cool, I'll let them out after work tomorrow.
Posted 14 May 2012 - 08:59 AM
They are also the same as MGF mirrors which does give you the option of having electric mirrors...Mirrors are the same as a Rover 100 / Metro.
