Wing Mirror Removal
28 replies to this topic
#21 TazN
TazN
  • 2,931 posts
Posted 14 May 2012 - 12:27 PM
The triangles can be a pain to get off. Had to destroy one of the things to get mine off, replaced with a much easier to use one. If you get a rover metro one then make sure it's externally adjustable rather than internally, otherwise it wont fit. They should come with the rubber ribbed section, mine cost £10 from local scrappy. If a screw falls into the door then a long magnetics screwdriver worked a treat :) Managed to find a variety of fixings in there...
#22 GiGo
GiGo
  • 5,657 posts
Posted 14 May 2012 - 03:30 PM
The MGF ones fit & also the MGTF ones which are electric & heated, I've got a pair waiting to get fitted & wired up when I find the time. As for getting the wing mirrors off I found it very simple but don't drop the screws!
Edited by GiGo, 14 May 2012 - 03:34 PM.
#23 RalphyBMW
RalphyBMW
  • 764 posts
Posted 11 May 2013 - 07:48 AM
Sorry to resurrect, but how do you get to the three fixings inside the door? Is the cover for these the "triangle piece" referred to above?
#24 techieboy
Posted 11 May 2013 - 08:09 AM
Yes.
#25 RalphyBMW
RalphyBMW
  • 764 posts
Posted 11 May 2013 - 09:24 AM
Cool, thanks
#26 wantsum
wantsum
  • 614 posts
  • Interests:Gaming and now fixing cars
Posted 11 May 2013 - 07:35 PM
Cool, thanks
and you might want to take the door panels off before you start for
when you drop one of the bolts inside the car :P
#27 RalphyBMW
RalphyBMW
  • 764 posts
Posted 11 May 2013 - 08:05 PM
Such confidence in my abilities!
#28 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 11 May 2013 - 09:05 PM
no need to take door panels off, just take the plastic cap at the side of the door near the lock mechanism, then just get an extendable magnet and you should find it that way, thats how i did it
#29 wantsum
wantsum
  • 614 posts
Posted 12 May 2013 - 12:03 AM
What abilities :groupjump:
