255/40/17
Posted 25 May 2012 - 07:14 AM
Posted 25 May 2012 - 07:53 AM
Posted 25 May 2012 - 08:17 AM
Do 225/45/17 fronts fit? I've heard 255 rears can cause rubbing issues if running lower than standard ride height, but may depend on a number of factors, including wheel offset, camber, spring rates etc.
Yes.. think mines are ET20 offset
Edited by jameso, 25 May 2012 - 08:18 AM.
Posted 25 May 2012 - 08:30 AM
Posted 25 May 2012 - 08:36 AM
I run 245 on ET20 offset with 110mm ride height and 3 Deg neg camber. Had rubbage inside and outside. Spaced wheel out 5mm and cut arches.
My rears are 9J ET30 - so was trying to work out whether to go with a 245/40 or a 255/40
Posted 25 May 2012 - 08:47 AM
Posted 25 May 2012 - 09:10 AM
My rear wheels are 8J ET30, with 245/40/17. No rubbing issues at all, but thats standard ride height using Exige suspension.
Indeed - So i was going to move to a 255/40/17 rear as my rear rims are wider - just trying to work out if it will still be rub free and not cause horrible understeer if the fronts are only 225
Posted 25 May 2012 - 09:21 AM
...and cut arches.
How? What does this look like and what work is needed?
//Johan
Posted 25 May 2012 - 09:23 AM
Posted 25 May 2012 - 10:33 AM
Edited by SteveA, 25 May 2012 - 10:36 AM.
Posted 25 May 2012 - 10:36 AM
I think i am the only one on here who can answer this question as I'm sure I am the only one to run these sizes. On the road 225F and 255R do not rub if spaced correctly. I currently run 225 Federal RS-R's on the front and 245 Yoko AD08's on the rear but I ran with a set of Potenza RE070 255's on the rear for a while without issues. The only reason I went for 245's is the clearance on 255's is very small and I thought the extra flex and cornering load of track use on the tyres could cause rubbing issues. It didn't catch in heavy road testing but I never got them on circuit TBH.
Mine must be too low with too much camber as I rubbed inside and out with a 245.
Posted 25 May 2012 - 10:39 AM
Edited by SteveA, 25 May 2012 - 10:39 AM.
Posted 25 May 2012 - 10:48 AM
Posted 25 May 2012 - 10:56 AM
Posted 25 May 2012 - 10:57 AM
Posted 25 May 2012 - 11:01 AM
Posted 25 May 2012 - 11:13 AM
Posted 25 May 2012 - 11:14 AM
Posted 25 May 2012 - 11:21 AM
A turbo owner of impeccable taste.
qft
