255/40/17
#21
Posted 25 May 2012 - 11:22 AM
#22
Posted 25 May 2012 - 11:30 AM
#23
Posted 25 May 2012 - 11:40 AM
#24
Posted 25 May 2012 - 12:22 PM
no, 225 is the sensible option
Maybe 235 at a push.
oi
#25
Posted 25 May 2012 - 12:25 PM
I think all of the more serious track drivers, JJJ, Cliffe, MaxR, Sizten, Joe, myself, etc, etc would disagree with you.
If you haven't driven both options I don't think you are really in a position to decide.
Edited by SteveA, 25 May 2012 - 12:26 PM.
#26
Posted 25 May 2012 - 12:29 PM
#27
Posted 03 June 2012 - 10:06 PM
#28
Posted 03 June 2012 - 11:21 PM
#29
Posted 04 June 2012 - 04:47 AM
#30
Posted 04 June 2012 - 01:54 PM
As MrSimba has insightfully stated, different tyres of the same supposed size will vary with considerably. R888s for example have a very pronounced sidewall bulge of approx 1cm static (more when under compression like a bump) and a lot of symetric feathing on both sides of the tyre. This sidewall buldge is one of the reasons I have decided to adopt a different tyre, as I would prefer less buldge and more contact surface area on the tarmac.
This kind of info is available on the internet to help you decide, eg: http://toyotires.com...mpetition-tires (click on the specification tab).
If you want maximum contact area with the tarmac, I'd generally advise swapping to a rectangular profile. The V70a tyres for instance have a mild upswept outer edge (only) that is not detectable until they are inflated, so appear rectangular on the shelf, but are in fact feathered nicely (asymetrically) for progressive break away at the limit. Subtle stuff for most of the people on here, but if you are serious about your car sticking on the road, then you will make the effort to investigate further
As an extra tit-bit, the V70a are standard issue for factory Ultima GTRs. As this car holds the world record for 'production car' 0-100-0 MPH on these tyres, that is a recommendation in itself. (The term production car is used rather losely though!!). I have also driven one of these things, and it was one of the memorable things in my life, though there are a few VX220s out there now that can match them
GL.
Edited by Nev, 04 June 2012 - 02:03 PM.
#31
Posted 04 June 2012 - 03:19 PM
http://www.willtheyfit.com/
http://www.tyres-pne...nce-advice.html
Good luck, I hope you get a good fit, don't forget to let the community know your findings (good or bad!).
Cheers,
Nev.
Edited by Nev, 04 June 2012 - 03:19 PM.
#32
Posted 04 June 2012 - 04:04 PM
#33
Posted 04 June 2012 - 04:15 PM
#34
Posted 04 June 2012 - 04:16 PM
#35
Posted 04 June 2012 - 05:57 PM
My rear wheels are 8J ET30, with 245/40/17. No rubbing issues at all, but thats standard ride height using Exige suspension.
Indeed - So i was going to move to a 255/40/17 rear as my rear rims are wider - just trying to work out if it will still be rub free and not cause horrible understeer if the fronts are only 225
255 rear and 225 front is a good setup, ET:20 you should be fine! I'm 9j 17 255 ET:25 rear and 7.5j 17 225 ET:15 front
#36
Posted 07 June 2012 - 12:10 PM
What wheels/rims are you running?
//Johan
#37
Posted 07 June 2012 - 01:11 PM
#38
Posted 07 June 2012 - 01:30 PM
#39
Posted 07 June 2012 - 04:05 PM
Got to agree with Steve with this one. With tuned VX's pushing more serious power the extra grip of wider tyres is a BIG help!!
I initially went over to the 245 rear as my Time Attack tyre was a normal road tyre and I needed to claim some traction against the 225 888's back by increasing the width of the tyre. Even with 888's on an exit of a bend I was still spinning up the rear tyres up when planting the throttle. All well and good but you know it's just wasted time (not to mention dangerous if you're not used to the back end moving around).
Here's a snap from the last corner at Anglesey (approaching the pit wall) and you can clearly see the rears spinning. Not the most flattering pic ever, ride heights were all over the place
Umar got it very wrong
Either way going over to 245's on semi's cured that and the rest is history
Honestly anyhting over 250bhp needs alot more tractio than a 225 offers in my opinion
#40
Posted 09 June 2012 - 07:37 AM
