Wheel Nut Torque Setting?
47 replies to this topic
#21 slindborg
Posted 14 June 2012 - 05:25 PM
I do it by feel and have always greased my bolts (mainly at the shoulder) as I've seen bolts 'welded' into hubs in the past.
#22 Ormes
Ormes
  • 4,612 posts
Posted 14 June 2012 - 05:27 PM
Thats because if you use a torque wrench for anything other than hub carrier bolts and head bolts you are a ... :D I'm learning aren't I slindy :)
#23 j0n
j0n
  • 1,491 posts
  • Interests:vx220
    Juggling
Posted 14 June 2012 - 05:59 PM
We do mine to 110nm. 90 is too loose I think. Undo that with my hand :mellow:
#24 slindborg
Posted 14 June 2012 - 06:01 PM
Note its not the bolt on its own that holds the rim to the hub.... its the combined clamp of 5 bolts :lol:
#25 Ansk
Ansk
  • 475 posts
Posted 14 June 2012 - 06:22 PM
I was talking with a techie from Nordloc just the other day, Torque is all about friction, so if you put copper grease on you would need a little extra torque, say 5 nm more Having said that I am sure there are large safety margins and no doubt most of us over tighten when we do it by hand, which is fine as long as you don't go past the yield point of the bolt
#26 slindborg
Posted 14 June 2012 - 07:09 PM
The Bosch Blue automotive handbook has a list of Lubrcants VS thread pitch tables for increasing the torque values if you so desire.
#27 Hark
Hark
  • 3,443 posts
Posted 14 June 2012 - 07:19 PM
I've always added a little copper slip after having a bolt weld itself to the hub. If 90nm is finger tight mine are alot tighter than that. Might just stuck with what I'm doing until I hear of someone stripping a thread.
#28 Claws
Claws
    Stage FA NA FTW!
  • 5,246 posts
  • Interests:Daft plastic cars
Posted 14 June 2012 - 07:59 PM
Jumping on the wheel brace till the nut gives a satisfying "CLICK" ...
#29 JG
JG
  • 13,617 posts
Posted 14 June 2012 - 08:16 PM
i do 100Nm, given that most torque wrenches are around 10% out.
#30 hairy
hairy
    Moonlander
  • 6,066 posts
Posted 14 June 2012 - 08:23 PM
mbes just reminded me, remember to throw away the lock nut and replace with standard bolt.
:yeahthat: x 4
:yeahthat:
#31 Denthrax
Denthrax
  • 272 posts
Posted 14 June 2012 - 08:42 PM
100-110nm. 90nm gets loose on track with my TD's :huh:
#32 slindborg
Posted 14 June 2012 - 08:46 PM
you haven't had yours calibrated? I'm shocked
#33 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 14 June 2012 - 08:47 PM
90Nm on mine and also copper grease on the ends and ive never had any problems on mine.
#34 sford
sford
  • 1,460 posts
Posted 14 June 2012 - 10:29 PM
Don't forget there is a correct order to tighten them as well!
#35 The Fat Man
The Fat Man
  • 336 posts
Posted 15 June 2012 - 12:27 AM
thumbsup:
#36 JG
JG
  • 13,617 posts
Posted 15 June 2012 - 05:57 AM
My small one is calibrated, rated up to 50Nm, the big cheapo one isn't :)
#37 starlight
starlight
  • 1,790 posts
  • Interests:Oily bits...
Posted 15 June 2012 - 07:31 AM
The handbook in the Europa says 110Nm. They are the same bolts and hubs... Although the paint shop that did the front end managed to tighten them to over 200Nm...
Edited by starlight, 15 June 2012 - 07:33 AM.
#38 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,516 posts
    "Yes, I built it"
Posted 15 June 2012 - 07:57 AM
:borg:
#39 wemorgan
wemorgan
  • 107 posts
Posted 15 June 2012 - 08:14 AM
A quality torque wrench should come with a calibration certificate. Mine is accurate to ~3% across the whole range
#40 techieboy
Posted 15 June 2012 - 08:17 AM
At time of testing.
