Would skinning a plastic come out ok & would that still not be worth you doing?
If you just wanted the look it would be far better and easier to have a half and half 'faked' one. Would look identical once installed and the fit of the clips etc would be guaranteed to be snug. When I can be bothered I'll probably make a few skinned ones as I have loads of CF fabric on a roll and plenty of resin etc. Just need to find a few cheap bog standard OEM covers from an Astra or something to use as a base. You could allways have a go yourself it's pretty easy to get a good result, buying small amounts of materials just for one small job may not be the most cost effective if your not going to make use of bigger quantities though.
Edited by -Dab-of-Oppo-, 26 June 2012 - 04:20 PM.
