Tullet Decat Silencer
Posted 27 June 2012 - 06:15 PM
Posted 27 June 2012 - 06:29 PM
Posted 27 June 2012 - 08:23 PM
Posted 27 June 2012 - 08:51 PM
Posted 28 June 2012 - 11:04 AM
Posted 28 June 2012 - 11:52 AM
Fitted the new silencer section in it's place on Saturday, for a trackday at Snetterton yesterday. I have to say, I was a little sceptical about how it could possibly make the system quieter, it looked more like it would actually make it louder. After fitting, it did sound a little quieter whilst idling on the driveway and I took it out for a drive and it felt like it might be a little quieter on the road. The static test yesterday was 96.2dB at 5200rpm, as opposed to 104/105dB at 4500rpm at Cadwell last time out. Will be interesting to see if that same low reading is repeated next month at Cadwell but I'd call that a success. I don't think it will get me on track at Bedford (or least keep me on track once I'm there) but I can live without that.
So it was a fair bit more than 3dB but, with the proviso that static noise measurement seems to be a fairly random thing, in my experience and seems pretty much unrepeatable. YMMV.
Posted 28 June 2012 - 12:08 PM
Posted 28 June 2012 - 12:11 PM
Posted 28 June 2012 - 12:19 PM
Posted 28 June 2012 - 12:25 PM
I wouldn't have said it was 8db quieter, mine probably dropped by 5-6db's in total.
No, I don't think so either. But static testing is totally random in my experience (as is drive-by testing) and is affected by too many external factors to trust any single reading. I'd get 10 different readings on the same day at the same place, hence the YMMV.
Posted 28 June 2012 - 12:28 PM
If only he would do some R&D into creating a 2.5" 93db system.
But, how? What works on one car and one engine may have no resemblance to how it performs on another car.
Posted 28 June 2012 - 12:30 PM
Posted 28 June 2012 - 12:54 PM
Posted 28 June 2012 - 02:17 PM
Posted 28 June 2012 - 03:02 PM
Static tests are just a stupid measurement and even when applied consistently they consistently produce inconsistent results.
I've been tested three times on one day and had different readings each time. On any given day, you could line up six ostensibly identical VX's with the same system on and I'd bet that each of them would give a different reading. Without creating a system that's no louder than an OEM system, how can a manufacturer legislate for those differences between cars and testing variances? What works on one car may or may not work on another car.
Look at Bedford. Infamously tight noise limits but the static test is 101dB that just about anything with an exhaust can pass. But, mega strict 88dB drive-by limit which, certainly in our case, is an absolute nightmare and the reason why evo generally only ever get one lap out of whatever exotica they put around the track there. If I'd bought the exhaust 3 years 6 months ago and I could get on at Bedford with it but, then the local council enforces tighter limits 3 months down the line that means the exhaust is no longer suitable, does that leave me with a claim against the supplier as it's no longer track friendly? How does this work one - one Thursday I take the car there to be tested for static and drive-by limits. The head instructor rags it around an empty track and radios back to the control room for the readings and I'm miles inside both. Six days later I go there for a trackday (with the car having done 16 miles back to the house and back to the track) and on my second lap I'm hauled in and told I'm 0.1dB under the drive-by limit and if I'm planning on staying, I'll have to lift past three of the four monitors.
What about Donington? When the Tullet exhaust was first designed and manufactured, Donington was a bankrupt building site with trenches across the track. Now it's re-opened and has a 98dB drive-by limit (measured in a totally different way to Bedford, I might add), was it down to Tullet to foresee that at the time they made the exhaust and design the system to fit within a limit that didn't exist and does the fact it might not meet those limits now mean it's not fit for purpose?
Maybe buy a 2Bular system if you can handle the possible infinite wait but it would appear that they're not all created equal either.
Like I said, I'm playing devils advocate here. I hate the system and the noise it produces. I'd love it if it made no more than a whisper. But, it doesn't and I'm resigned to that fact and that it'll be me that has to find a workable solution for my car if things are to improve.
Posted 28 June 2012 - 03:06 PM
Edited by iVXT, 28 June 2012 - 03:06 PM.
Posted 28 June 2012 - 03:08 PM
Why an arbitrary number like 93dB? What does than mean? Why not 95dB, 88dB or even 77dB?
93 on driveby was just sucked out of my thumb. less is better.
95 on driveby seems to be the most common bottom at tracks these days.
I have the same frustration as you that the most expensive part i ever bought for the speedster, sold as meeting track noise limits just does not cut it, and i am fiddeling with different back boxes, and db killer crap and whatever.
Just very disapointed with mr tullet atm.
Posted 28 June 2012 - 03:17 PM
I thought db was measured at 1m from tailpipe at the 45 degree angle as you said though?
That's what the MSA say. But environmental and operator factors have an inordinate influence over the numbers.
Actually MSA's recommendation might be 50cm's. See no consistency.
Posted 28 June 2012 - 03:27 PM
Measured how though? There doesn't seem to be a "standard" method to take those measurements. Where I've actually been bollocked and given my drive-by readings, I've measured 101db (in a 98dB limit) at a couple of metre's above the track and 88.2dB at what's meant to be 20 metres away from the track. No consistency.
If the Tullet system passes the 105dB limit at Silverstone can he not claim that it meets trackday noise limits? He's not actually claiming it meets every track's noise limit. Likewise, does he claim to meet any European track limits? I don't know. Does the fact it's no good for Zandvoort mean it's not track safe somewhere else.
Whatever else, a silencers effectiveness reduces over time, so at some point it's going to fail a test even at a 105dB day somewhere.
Posted 28 June 2012 - 03:50 PM
