Plan B, It Looks F***ed (Pic Heavy)
40 replies to this topic
#1 siztenboots
Posted 14 July 2012 - 05:08 PM
I'm no expert, but now we have stripped off the cylinder head today to have a look, its not looking so clever for getting to Le Mans
the anticipation
right here go
cyl #1
cyl #2
cyl #3 after gasket removed
and the exhaust side
cyl #4
#2 CocoPops
CocoPops
  • 17,182 posts
Posted 14 July 2012 - 05:13 PM
Oh nice valve marks thumbsdown
#3 siztenboots
Posted 14 July 2012 - 05:45 PM
not sure what you mean, the valve seat pockets for the inlet valves, they are cast into the piston
#4 CocoPops
CocoPops
  • 17,182 posts
Posted 14 July 2012 - 05:48 PM
Ah, my mistake then. I thought they were caused by valve meeting piston.
#5 SteveA
SteveA
  • 9,159 posts
Posted 14 July 2012 - 05:50 PM
He's an N/A boy, their pistons don't have seat pockets so I'm guessing that's where the confusion is coming from. So is that a rebore and some new rings then Steve?
Edited by SteveA, 14 July 2012 - 05:51 PM.
#6 siztenboots
Posted 14 July 2012 - 05:56 PM
symptoms: pressurising coolant expansion tank, sometimes exhaust steam on first start I think its a HGF on cyl #3 on the inlet valve side (there is a more marmalade colour look to the water jacket) , although there is no sign of any oil / water mix up.
#7 SteveA
SteveA
  • 9,159 posts
Posted 14 July 2012 - 05:57 PM
Are those scratches on cyl3 exhaust side?
#8 siztenboots
Posted 14 July 2012 - 06:01 PM
yes, there are some vertical marks
#9 FLD
Posted 14 July 2012 - 06:46 PM
I still have access to that brand new engine if you fancy a straight swap.
#10 techieboy
Posted 14 July 2012 - 06:48 PM
T-cut will remove that. thumbsup I assume that's just a dried trickle of rusty water in cylinder 3 and not some nasty crack in the wall? I guess it's a case of remove the the piston, rehone the cylinder and refit piston with new rings. Light skim of the head and new head gasket and away you go.
#11 JG
JG
  • 13,617 posts
Posted 14 July 2012 - 07:11 PM
None of the oil ways to water way seals look bad tbh, the seals between cyclinder and water ways look mostly good. hard to tell whether its cyl3 or not. that trickle down the bore is probably a prettty good indication but you would usually see a mark in the seal. either way a clean up and a new HG will sort you out.
#12 fezzasus
Posted 14 July 2012 - 07:47 PM
Doesn't look that bad to be honest, I'd reskim and rebuild - the rust marks will be removed as soon as the engine starts running
#13 alanoo
alanoo
  • 1,324 posts
Posted 14 July 2012 - 09:35 PM
Honestly I think this one could even go without a new piston/rehone too Check the head, reskim if needed, new HGF and go !
#14 Nev
Posted 15 July 2012 - 07:32 PM
I'd check carefully that the rusy water was deffo coming from HGF and not porosity/micro crack at the top of the cylinder bore. If it was the former, I'd just clean it up and put the head back on with a new HG and see if the problem has gone.
#15 siztenboots
Posted 16 July 2012 - 08:29 AM
todays shopping list , 10x of the new bronze colour exhaust manifold studs and the special nuts coolant flush oat coolant , lots of it I've got a ton of update pictures to upload and document all the work we did on Sunday.
#16 siztenboots
Posted 16 July 2012 - 02:34 PM
quite handy that eurocarparts have a 31% discount , so this lot only came to £25 including delivery 1 x 523770481 @ 17.59 GBP TRIPLE QX Red Anti Freeze 5Ltr ---- 2 x 545771181 @ 4.80 GBP Valvoline Radiator Flush 350 ML ---- 2 x 542770340 @ 2.48 GBP Pagid Concentrated Brake Parts Cleaner ---- 1 x 553771620 @ 4.00 GBP Carplan De-Ionised Water 5Ltr
#17 fezzasus
Posted 16 July 2012 - 02:53 PM
The coolant system is 13 L in total, so might want to grab another 5L of deionised water
#18 siztenboots
Posted 16 July 2012 - 03:07 PM
i did a search , but only found 2.2 threads , and the capacity seemed to vary. I'm going to try and give it two flushes through as it looks like canal water at the moment. the water pump has been replaced with new, the old bearings had play (I think this was my angry menacing mechanical noise at high rpm) and it was leaking past the outer seal. I've fitted a new thermostat housing , new water block housing ( with temp sensor ) as it seemed that the ally was okay, but the metal pipe for the hoses had rust. All new gaskets for everything, ran a tap through all the threads and cleaned up all the surfaces with a razor blade first, then gave them a good going over with an india stone. the cylinder head has been tested for flatness on my engineers table and restored back to factory fresh and a lot of work with the india stone
#19 siztenboots
Posted 17 July 2012 - 12:13 PM
cleaned up and inspected the old turbo, decided against putting the high power new turbo on
for ease of reinstallation, we built the turbo up to the head, rather than try and do this in the engine bay
this is where we are at right now, head gasket on, head bolts in, but I need to pop out and get a 1/2 to 3/8 adaptor for the small torque wrench
#20 siztenboots
Posted 17 July 2012 - 07:01 PM
major problems with the tensioner kept jumping the belt, causing us to have to spend ages finding tdc again, but its nearer...
