Posted 04 August 2012 - 08:32 AM
Posted 04 August 2012 - 08:52 AM
Posted 04 August 2012 - 10:05 AM
Posted 04 August 2012 - 10:20 AM
Posted 04 August 2012 - 11:01 AM
I have a standalone ecu that can change maps on the go. Its the Adaptronics unit supplied And fitted by chris from efi parts. Its amazing what it can do and has the added bonus of a cable operated throttle body.
How are you finding the adaptronic,do you find the throttle. Bit on off?
Posted 04 August 2012 - 11:50 AM
Posted 04 August 2012 - 12:01 PM
Posted 04 August 2012 - 12:38 PM
Posted 04 August 2012 - 02:22 PM
From some research I did ages ago you can sensibly expect 370 BHP from a GT2871 with a Z20LEx, perhaps 380. I have overlaid several dyno plots below, the black line is a GT2871. Obviously every car will be different and the resulting power/torque depends on so many things, so you can only use it as a rough guide. Incidentally, the GT2871 plot was one given by Klassen a long time ago, still using the OEM ECU.
If you are using a Pro-Alloy CC, you might find the power is limited by the max boost the they recommend you run though it. On my car that's just 2.0 bar, you better check what your limit is otherwise over time the alu side walls of the CC may fail from metal fatigue due to constant changes of boost being applied.
HTH.
Edited by Nev, 04 August 2012 - 02:25 PM.
Posted 04 August 2012 - 02:48 PM
It will be interesting to see how mine will fit in with those with the Dave/Duncan mega intake kit and the standalone ECU giving the engine that extra bit of freedom.
I blew up my charge cooler a long time ago! Iv currently got a super duper over the top carbo-tanium reinforced one!
2 bar is a lot of boost and certainly more than I envisaged it running. What kind of pressure is this turbo capable of and what pressure would you consider a reasonable amount to run before heat becomes a big issue?
Posted 04 August 2012 - 03:08 PM
That’s really good stuff Nev, thanks. I don’t suppose you know what boost levels were used to produce those figures do you?
Sorry, no idea about the boost levels used to create those maps
I suspect Duncans larger airbox/pipework will make quite a bit of difference, maybe a lot (like +25 BHP even) - such things become more and more influential as you go up in turbo sizes.
2 Bar isn't mega boost really, it's perfectly normal for a mid sized turbo. It's just that the OEM one is titchy so everyone gets used to that maxing out at around 1.4 Bar of steady boost. The GT2871 (depending on housing choice) is capable of a (usable/efficient) pressure ratio of around 2.6 bar, so providing your inlet pipework doesnt cause much of a resistance you can expect 1.6 Bar of steady boost, and a bit more on top of that if you really want to max it out.
I dunno what heat to expect, if you have the smaller hotside A/R snail you may get back pressure heat issue in the manifold and cylinder head due to the restriction of the snail. If you havent chosen the smallest A/R snail then you will likely be fine for heat, especially if you wrap it all with heat wrap.
Good luck with the CS hardware, hopefully their remedial work has finally worked.
Posted 04 August 2012 - 03:59 PM
Posted 04 August 2012 - 04:07 PM
Strangely, the AR wasnt written on the housing. But from previous chats with CMS, the enphasis was always on minimal lag. It never crossed my mind at the time that this could cause further temp issues.
Well it ran 345bhp just before the 5k rpm mark at 18-19psi last time. So im excited to see what happens when an extra 5 0r 6 psi is added on to that and its aloud to rev past 5k.
From reading that, maybe your final map will get pretty close to (or creap over) 400 BHP then, cos making 345 BHP with just 1.2 Bar of boost leaves quite a bit of headroom for the turbo.
I can't remember, but do you have:
1: Oversize valves?
2: Strong valve springs?
Edited by Nev, 04 August 2012 - 04:08 PM.
Posted 04 August 2012 - 04:16 PM
Posted 04 August 2012 - 04:37 PM
Posted 04 August 2012 - 04:44 PM
Posted 04 August 2012 - 06:15 PM
Posted 05 August 2012 - 08:16 AM
Posted 05 August 2012 - 11:40 AM
Edited by Nev, 05 August 2012 - 11:49 AM.
Posted 05 August 2012 - 03:22 PM
