What Could Go Wrong? Wheels?
35 replies to this topic
#1 Papy11
Papy11
  • 95 posts
  • Interests:Track days, Plancha, wine
Posted 31 August 2012 - 03:51 PM
Hi all, Due to finances and the need to get more grip on track, I have purchased spare rear wheels to fit at the front. My plan is 235/50r17 rear and 225/50r17 front all on feredal 595. Am I daft or what? can it work at all? Well, all comments welcomed!
#2 JohnTurbo
JohnTurbo
    SuperScruff
  • 3,635 posts
  • Interests:Performance cars!
Posted 31 August 2012 - 04:05 PM
Go for 205 front, run spacers. You'll be fine.
#3 SteveA
SteveA
  • 9,158 posts
I have rears on the front with 225 federals. You will need spacers to make the offset between 20 and 24 (mine is 23) and you need to do the sill mod if you want to use any more than 1 lock of steering.
#4 Rickwoo118
Rickwoo118
  • 5,800 posts
Posted 31 August 2012 - 04:11 PM
Won't the steering be a bit heavy?
#5 SteveA
SteveA
  • 9,158 posts
Posted 31 August 2012 - 04:13 PM
Nope it's fine. I also have 245 rears.
#6 christhegasman
christhegasman
  • 5,316 posts
  • Interests:cars
    motorsport especially BTCC
    rugby
    eating out
    keeping fit
Posted 31 August 2012 - 05:06 PM
205/40/17 on mine with rear rims on the front
#7 jameso
jameso
  • 2,336 posts
Posted 31 August 2012 - 06:06 PM
I'm same as Steve on 225 fronts and 245 rears - unless you have mega power I would be tempted to go narrower rims and 215F 235R and same weight on each corner
#8 Nev
Posted 31 August 2012 - 06:47 PM
Steering is only heavy upto 3 MPH and then it's fine.
#9 Papy11
Papy11
  • 95 posts
Posted 01 September 2012 - 09:49 AM
I run 240/250 bhp. Are you guys saying that 205, 215, 225, 235 or 245 can all be fitted on standard turbo rear wheels? 40 or 50?I also don't understand what "same weight on each corner" means. Bearing in mind it's for track use.
Thanks
#10 siztenboots
Posted 01 September 2012 - 09:59 AM
235/40/17 and 205/45/16 here on federal rs-r
#11 Papy11
Papy11
  • 95 posts
Posted 01 September 2012 - 10:10 AM
Sorry siztenboobs :D , but all 4 will be 17.
#12 siztenboots
Posted 01 September 2012 - 10:12 AM
i have also run the 225/45/17 setup on those tyres as well, as well as fronts on the back 16" all square setup
#13 Papy11
Papy11
  • 95 posts
Posted 01 September 2012 - 03:54 PM
OK, feredal 595 So 245/50r17 rear and either 225/50r17 front with 23mm spacers or 205/40r17 rear (spacers?) And all that on standard 7.5j x 17 rear wheels would work? Thanks again
#14 christhegasman
christhegasman
  • 5,316 posts
  • Interests:cars
    rugby
    eating out
    keeping fit
Posted 01 September 2012 - 03:57 PM
Lost me mate I have na rear rims on all 4 corners and run standard 225s on the rear And 205/40 on the front
#15 Papy11
Papy11
  • 95 posts
Posted 01 September 2012 - 04:04 PM
I think I lost myself too! red wine you know!! I'll start again: Rear 245/50r17 Or 225/45R17 Front 225/50R17 with 23mm spacers Or 205/40r17 (Would I need spacers?) Best combination for track considering understeer, grip, etc.? David
#16 christhegasman
christhegasman
  • 5,316 posts
  • Interests:cars
    rugby
    eating out
    keeping fit
Posted 01 September 2012 - 04:16 PM
I'll start again:
Rear
245/50r17
Or
225/45R17
Front
Or
205/40r17 (Would I need spacers?)No spacers no rubbing
David
Edited by christhegasman, 01 September 2012 - 04:17 PM.
#17 Crabash
Crabash
    Scared
  • 1,686 posts
Posted 01 September 2012 - 05:01 PM
Not 50 profile on rear, 245/40/17 are tight, 235/40/17 give more space and either 205 or 215/45 on front.. Not sure what 245 on standard rear wheels is like.
#18 Papy11
Papy11
  • 95 posts
Posted 01 September 2012 - 05:20 PM
Thanks Crabash. To sum up: 235/40/17 Rear 205 or 215/45/17 Front Do you know what spacer is required at the front for those size?
#19 Crabash
Crabash
    Scared
  • 1,686 posts
Posted 01 September 2012 - 09:02 PM
Sorry I dont, all I can say is the rears are ET35 and fronts ET26. To clarify 235 and 205 or 245 and 215 is what I would use to retain a similar size ratio (diameter) front to rear as standard.
Edited by Crabash, 01 September 2012 - 09:03 PM.
#20 siztenboots
Posted 02 September 2012 - 07:09 AM
225/45/17 with a R rating tyre is the widest you can fit on the 7.5" wheel, even then sidewall probably will not sit on the bead and the fitter will struggle. If you search for R888 and fitting problems its well known.
