These could be totally unrelated.
If I change from 3rd to 4th at high revs and apply WOT, my VXT seems to hesitate momentarily, this is typically around 4k rpm I believe. It isn't really a problem but I don't believe it should do this.
Otherwise the car is absolutely fine to drive, nothing strange happening.
Over the next few days I am going to change the plugs and air filter, more in the interests of ruling them out, and despite the FSH I am not certain when these were last changed.
Beyond that I am thinking either;
- AMM - Turbo hose (replace with Pro Alloy?)
- Intercooler - inlet manifold hose (replace with silicon? If so where can I get this
- AMM itself - is it worth replacing with the 80mm Astra VXR item? Wouldn't a faulty AMM show other symptoms?
Any suggestions as to whether or not this is a sensible course of action, or anything that I might not have considered?
Possibly related, possibly not, the car very kindly illuminated the CEL for my birthday, and showed the code P1106. From what I can gather, this code seems to relate to the MAP sensor. I have read several posts about it but nothing seems to close itself off.
Having reset the code, I took the car out for a good drive, got it nicely warmed up and tried to check power delivery in each of the gears, it was in doing this that I identified the hesitation in 4th, though 1-3 all seem fine.
Any suggestions gratefully received!
