Ok, actuator rod seems seized, what do I do?
Vxt Hesitation In 4Th, & P1106
Started by
RalphyBMW
, Sep 10 2012 05:10 PM
23 replies to this topic
#21
Posted 11 September 2012 - 09:36 PM
#22
Posted 11 September 2012 - 10:20 PM
When I say seized, I couldn't move it by hand. I didn't try moving it with pliers or anything.
#23
Posted 12 September 2012 - 05:04 AM
I use a monopod (photography), works a treatprop the boot lid with something much longer (I use an umbrella) so you get full access
#24
Posted 16 September 2012 - 09:26 AM
Ended up using the handle from our Dyson to keep the boot open.
Wastegate seems fine, I just wasn't pushing hard enough. Once I knew which way I was supposed to be pushing I used a bit more force and it moved smoothly.
Upper head shield is an AWFUL device, went back in easier than it came off though.
I have replaced the spark plugs and air filter, need to fine my misplaced contact cleaner and clean up some of the connections.
