Mixed success!
Seals came, seals changed but the leak persisted. Moved the Injector and the leak moved!
Looks to me like the Injector itself has a split in it...not visible, but clearly doesn't like being put under pressure when cold! I'll PM G-Bob about one of Rossco's Injectors.
Is this a common fault?
Z22Se Leaking Injector
Started by
Claws
, Sep 13 2012 10:04 PM
21 replies to this topic
#21
Posted 19 September 2012 - 07:35 PM
#22
Posted 23 September 2012 - 11:36 AM
Great success!
A big thanks to Bob and Ross, met up with Bob last night to get the injectors Ross removed from his car. Fitted one of them this morning, no leak!
Roof off, grin on!
Thank you .org
Just a side note, the part numbers are different and the new injectors have a plastic sleeve on the middle barrel/body of the injector, it's physically the same size and works great...is that just a revised version from Ross's newer car compared to my early 2001 job?
