Fog Light Bulb Changing...
Bastard Lights!
60 replies to this topic
#1 CocoPops
CocoPops
  • 17,182 posts
Posted 24 September 2012 - 07:28 PM
So, I did a search looking for foglight bulb changing and found a thread that said remove plub, unscrew back and job done. However, neither rear will unscrew from the foglight front. They won't even budge. I can't see too well as they're in the rad surround almost and access isn't great through the headlight opening. There does seem to be a little clip on the back of each foglight, but again I can't shift it. Any pointers?
#2 Wolfstone
Wolfstone
  • 12,987 posts
Posted 24 September 2012 - 07:32 PM
It is a royal PITA Lee. James.a, Ollyj and I changed a fog light bracket the other weekend which involved re-assembling the fog light, bulb etc after the new bracket was in. It can be done but you work effectively blind. That little metal clip comes away and releases the wiring.
#3 Anarchy
Anarchy
  • 2,237 posts
Posted 24 September 2012 - 07:33 PM
Good luck, small hands and a good grip required, the back should turn but the fun does not end there. The spring holding the bulb in place, the clip holding the connector all a pain in the ass.
#4 CocoPops
CocoPops
  • 17,182 posts
Yep, that's the "easy" bit Ken! :) I have both wires detached, but just can't twist the rear :unsure:
#5 JG
JG
  • 13,617 posts
Posted 24 September 2012 - 07:34 PM
You do ask some fucking stupid questions :D :lol: :P
#6 CocoPops
CocoPops
  • 17,182 posts
Posted 24 September 2012 - 07:35 PM
At least I searched ;)
#7 CocoPops
CocoPops
  • 17,182 posts
Besides, get over here and fix it!
#8 CocoPops
CocoPops
  • 17,182 posts
Posted 24 September 2012 - 07:36 PM
It was Ken's post here: http://www.vx220.org...b/#entry1178537 That made it all sound soooo easy! :lol: I blame Ken! :lol:
#9 JG
JG
  • 13,617 posts
Posted 24 September 2012 - 07:39 PM
now? :unsure:
#10 JG
JG
  • 13,617 posts
Posted 24 September 2012 - 07:42 PM
I mean how hard can it be? :lol:
#11 Nelly Vx
Nelly Vx
    3/3 Of a Queen
  • 5,928 posts
Posted 24 September 2012 - 07:47 PM
I had the same problem lee , turned out the back of the lamp had melted and the cap would not turn off , second hand lamp veccy gsi off eBay :-)
#12 CocoPops
CocoPops
  • 17,182 posts
Deffo no locking tabs? Cos the rears will NOT rotate. :unsure:
#13 Wolfstone
Wolfstone
  • 12,987 posts
Posted 24 September 2012 - 07:48 PM
I blame Ken! :lol:
That guide came from nelly. Blame him! :lol:
#14 JG
JG
  • 13,617 posts
I'm on my way :rolleyes: :D
#15 CocoPops
CocoPops
  • 17,182 posts
Posted 24 September 2012 - 07:49 PM
Hmm cheers Neil. Looks like I'm putting headlights back in and will save it for a rainy day when the clam can come off.
#16 Nelly Vx
Nelly Vx
    3/3 Of a Queen
  • 5,928 posts
Posted 24 September 2012 - 07:55 PM
The side I needed to remove the two Allen bolts at the bottom had rounded off , needed to dremel these off and then removed the lamp and bracket from out of the head lamp hole , it was only when I had the lamp out you could see the lamp had melted :-/
#17 turbobob
turbobob
    2/3rds of a Queen
  • 13,833 posts
    Photography
    CARS!!
    Travelling
Posted 24 September 2012 - 07:59 PM
I don't think I've ever used my fog lights. Do people actually use them?
#18 CocoPops
CocoPops
  • 17,182 posts
Posted 24 September 2012 - 08:22 PM
Right, so.... SuperJG visited... swore, and then decided there WAS a locking tab (little plastic clips) that came out with a screwdriver. (No idea where they are now, but it appears they're not needed). Then, next issue... The thread I found previously said the bulbs are H1... So I had 2 H1s to go in and they are actually H3 :( So, the job continues into another day when I can get back to Halfords to buy the right Bulbs!
#19 JG
JG
  • 13,617 posts
Posted 24 September 2012 - 08:23 PM
Piece of piss. :P If he'd bought the right bulbs, they'd be working now :lol: :D
#20 PHB1969
PHB1969
    Premium Member
  • 946 posts
Neither of mine are working and haven't since I bought it in January. Have tried the switch but it isn't that, have checked the fuse but it isn't that so assume both bulbs have gone over time. Are these an MOT requirement?
