Edited by Gilgamesh, 12 July 2013 - 11:05 PM.
Tail / Brake Light Bulb Keeps Blowing
Started by
Andy_VX
, Oct 26 2012 08:24 AM
23 replies to this topic
#21
Posted 12 July 2013 - 11:00 PM
I seem to have same problem with the drivers side rear bulb, keeps blowing and melted the plastic, have been replaced 4-5 times last months... annoying as hell
#22
Posted 12 July 2013 - 11:41 PM
Get LED ones, no problem
#23
Posted 13 July 2013 - 07:00 AM
#24
Posted 13 July 2013 - 07:21 AM
Should have said that I sorted mine. Removed the offending light unit and found that some of the plastic around where the bulb sits had melted into a nice blob that made the bulb a tight fit. Took a dremel to flatten it back down and it's been perfect since. I believe that led bulbs can add there own set of problems causing other bulbs to flicker.Remove the light and check for clearance around the bulb. A bet it is out of shape and the close proximity of the bulb to the light fitting causes it to over heat and blow.
