Must Have Mods For Track Use?
24 replies to this topic
#1 Thealastair34
Thealastair34
  • 988 posts
Posted 03 December 2012 - 09:06 PM
i have a n/a and the mrs is wanting to get into trackdays in the car along with me, the plan never way to track it much really but she would rather use the vx than the kit car untill she is happy with driving on track which i understand. my question is for a n/a car what mods would people undertake to make sure the car will be happy on track? i took it to the ring this year and put a few laps in and also did a 20 min session of the GP circuitover there and the car was fine. Currently has 1144 pads f+r gaz golds and TD wheels, with braided lines and 5.1 fluid. was thinking of more track pads like rs14 and some ad08 tyres as the khumo kh31 and nearly past it, although i was worried that if i increase the grip i may need to upgrade the engine in terms of a sump baffle? or do they cope with track work ok in standard guise thanks for any input! alastair
#2 Phear
Phear
  • 1,125 posts
Posted 03 December 2012 - 09:10 PM
You've got most of the bases covered there, if you decide go semi-slick tyres I would uprate the tie-rods though.
#3 JG
JG
  • 13,612 posts
Posted 03 December 2012 - 09:11 PM
start with it standard. you can 'improve' later :) Its as much fun changing, adding, reversing and experimenting as it is anything else. if you start with it already in best shape the whole experience is slightly less rewarding.
#4 GeorgeBC
GeorgeBC
    Needs a cheaper hobby
  • 3,138 posts
Posted 03 December 2012 - 09:14 PM
And hub carrier bolts. Maybe an alloy rad? Harnesses. Gearbox breather.
#5 Thealastair34
Thealastair34
  • 988 posts
Posted 03 December 2012 - 09:16 PM
its not standard at the moment,
but didnt want to go to spa in march for example to find that i just kill the pads after one hard session with afew hours to go after if that makes sense.
i dont know a massive amount the limits of these cars or engines so though i would throw it out to the experts ;)
#6 rob999
rob999
    Cat in a Hat
  • 12,795 posts
Posted 03 December 2012 - 09:20 PM
More driver training :)
#7 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,353 posts
Posted 03 December 2012 - 09:21 PM
Gearbox breather, new brake fluid and decent pads then just go enjoy. It is a great car as it is.
#8 Thealastair34
Thealastair34
  • 988 posts
Posted 03 December 2012 - 09:35 PM
Is there a breather kit available to buy or just make you own kind of thing
Was going to change the pads anyway, and the tyres need changing soon anyway
#9 Boombang
Boombang
    Saxo boy
  • 3,022 posts
Posted 03 December 2012 - 09:42 PM
All you need to make a breather really is a length of hose. Coil it upwards and point well away from tyres.
#10 SteveA
SteveA
  • 9,157 posts
Posted 03 December 2012 - 10:24 PM
Spot on. Id fit an abs cutoff switch on there just incase.
#11 siztenboots
Posted 04 December 2012 - 09:05 AM
fit new hub carrier bolts fit new rear toelinks don't rush to fit super sticky tyres
#12 westie
westie
  • 588 posts
  • Interests:Spending money on the car, Winding up the wife, Pickled onion monster munch, Terraforming.
Posted 04 December 2012 - 01:34 PM
Invest in a tow car and trailer, best track day mod I did.
#13 FLD
Posted 04 December 2012 - 02:37 PM
Gearbox breather is a must to avoid spraying gear oil on your NSR tyre. Other than that just make sure the car is in good order.
#14 jonnyboy
jonnyboy
    The hardtop guy
  • 8,290 posts
Posted 04 December 2012 - 02:58 PM
More driver training :)/>
This. Along with regular stuff like maintaining your brakes and tyres even stuff you have already like the gaz and wheels isn't necessary.
I've done 30 odd days in vx's all of them near standard. Never tracked the SC. Well not after the conversion anyway.
Pretty well anything you do to a vx that will improve track performance will compromise it as a road car.
#15 VIX
VIX
  • 9,497 posts
Posted 04 December 2012 - 03:30 PM
Bear in mind that 10 years ago these cars were being tracked straight out of the showroom with no mods at all. First mods, when needed, were brake pads and a decent geo. Other than that (and assuming fresh fluids) fit an ABS cut-off switch and go for it. chinky chinky
Edited by VIX, 04 December 2012 - 03:32 PM.
#16 jonnyboy
jonnyboy
    The hardtop guy
  • 8,290 posts
Posted 04 December 2012 - 04:47 PM
Oh yes ABS cutoff is a good call. Essential call actually if you dont want your day frustrated by the stupid ABS!
#17 Thealastair34
Thealastair34
  • 988 posts
Posted 04 December 2012 - 11:10 PM
Thanks, It has abs disconnected, has been since I've had the car At least I know I don't really have to worry about changing anything, the engines I'm normally used to suffer from oil surge and that was one of my main concerns regarding using the vx on track. We best go book some stuff!
#18 Chacha
Chacha
  • 254 posts
Posted 18 December 2012 - 09:52 PM
Iphone dashboard mount and Harry's lap timer pro app!
this is what you can get as a result of your £20 investment:
#19 JG
JG
  • 13,612 posts
Posted 18 December 2012 - 10:00 PM
Quite good that
#20 dw1
dw1
  • 3,043 posts
Posted 18 December 2012 - 11:26 PM
Quite good that
For £20 that's epic!
That and better pads and abs cut off, when the abs kicks in it gets the fluid hot quicker.
Edited by dw1, 18 December 2012 - 11:31 PM.
