With adjustable stops the height and length of the pedal can be set so the pedal height relative to the brake pedal can be set as well as the travel of the pedal.
The amount of cable movement can then be set by selecting different positions for the ball joints and cable fixing to suit the throttle body used to achieve full opening.
A spring can also be used between the body and pedal rod to assist pedal return if required.
Dave.
