Toe Link Kit Installation Vx220Na
toe link VX220Na
47 replies to this topic
#21 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,516 posts
    "Yes, I built it"
Posted 13 May 2013 - 10:42 AM
TazN, check this link, they are used as they are key'ed for the chassis.
http://www.lotustalk...434/index7.html
#22 TazN
TazN
  • 2,931 posts
Posted 13 May 2013 - 01:55 PM
Yep, when I got under the car again this morning I cleaned the area up and it was very obvious that it has an indentation for it to snugly fit into. Very interesting thread though.
Both inner's are now in place and the N/S outer is on. Just wrestling with the O/S outer as it's providing the same problems as I mentioned earlier in the thread. Not too sure how I solved it as when I went down this morning it just went straight together. I can almost see the car being on the ground once again but the weather is saying otherwise :(
#23 Arno
Arno
  • 1,238 posts
Posted 13 May 2013 - 07:34 PM
Only slide the outer bolt in after you put the toe link outer joint right up to the upright connection.
This way you reduce the angle the toe link makes compared to the upright.
Otherwise the outer ball of the toe link can't rotate far enough with the bolt through it to come completely vertical and you can't get it to slide into the upright.
#24 TazN
TazN
  • 2,931 posts
Posted 15 May 2013 - 07:32 PM
Right just about fed up of this toe link kit. Tried fitting it again tonight, thought I'd remove the one I'd manage to fit and put the opposite side to a similar position/length. Ended up putting a small nick in the dust cover :( take it this now needs to be replaced?
Toe links are from elise shop, will the EP covers be fine/fit?
http://www.elisepart...it-dust-covers/
Sorely tempted to buy 2nd hand oem and fit them so I can just take it to the garage to fit.
#25 Sticky
Sticky
    iTB lover
  • 3,462 posts
Posted 15 May 2013 - 07:58 PM
How have you attached the additional bracket to the subframe?
#26 Crabash
Crabash
    Scared
  • 1,686 posts
Posted 15 May 2013 - 08:06 PM
I would replace yes. The EP ones will be fine.
Don't assume a garage will fit them properly either!
#27 TazN
TazN
  • 2,931 posts
Posted 15 May 2013 - 08:44 PM
Shear bracket is bolted on with the m6 (I think) bolts provided.
After calming down I've re looked at the toe links, one of my outer ends sits at an obvious angle compared to the other. I would imagine this difference to be the cause of one side not fitting... I presume they don't rotate (except on the thread) as mine have been solid since I got them so cant see how to adjust for this. - Excuse the funky patterned blanket on the floor!
Any advice on how to remove the inserts without destroying the rubber cover?
#28 Captain Vimes
Captain Vimes
  • 2,755 posts
Posted 15 May 2013 - 08:49 PM
It's a spherical joint that's designed to twist as the suspension goes up and down. Put a bolt through it and align it to vertical... It may be stiff so encourage it with a small adjusting tool (hammer)..
#29 Sticky
Sticky
    iTB lover
  • 3,462 posts
Posted 15 May 2013 - 08:52 PM
I have the EP kit. With appropriate lubrication the boots come off and go on quite easily. With my kit loosening the sheer bracket allows you to fit the toe link and subframe spacer piece, insert the long bolt then do up the sheer bracket bolts. Need to ensure the boot isn't nipped anywhere.
#30 Sticky
Sticky
    iTB lover
  • 3,462 posts
Posted 15 May 2013 - 08:54 PM
Or put the bolt through and waggle it. My EP ones were a bit stiff initially but this and some lube soon sorted that.
#31 jules_s
jules_s
  • 15,275 posts
  • Interests:Plane spotting
Is this the parallel M10 kit?
#32 Crabash
Crabash
    Scared
  • 1,686 posts
Posted 15 May 2013 - 08:57 PM
Did you not fit the rubber boots yourself?
#33 TazN
TazN
  • 2,931 posts
Posted 15 May 2013 - 09:02 PM
:beat: so simple >_<
bolt in and had to really wiggle it to get it to move but both outer ends now have some movement in them. Thinking about it now though I can see how they need to move otherwise the rear wheel would be at a set height constantly....
Jules I forget which it is though I believe ES send both insert types encase you order the wrong ones.
#34 Captain Vimes
Captain Vimes
  • 2,755 posts
Posted 15 May 2013 - 09:04 PM
Sorry. I thought about posting something similar yesterday but thought it was too obvious. Glad you got it sorted :-)
#35 jules_s
jules_s
  • 15,275 posts
Posted 15 May 2013 - 09:05 PM
VX220parts.com now seem to give you the choice The guy fitting mine has specifically told me its the parallel M10 kit needed for my NA, so hopefully it'll all go well :)
#36 Sticky
Sticky
    iTB lover
  • 3,462 posts
Posted 15 May 2013 - 09:08 PM
When getting the main bolt through the subframe end you might find it easier to push another bolt in from the other side whilst you faff around getting the toe link, spacer washer thing and the sheer bracket sorted. The wishbone/bush then remains exactly lined up when it comes to inserting the proper bolt from the back, it should slide straight in. (Pushing the temporary bolt out as it goes in)
Edited by Sticky, 15 May 2013 - 09:09 PM.
#37 TazN
TazN
  • 2,931 posts
Posted 15 May 2013 - 09:12 PM
I thought they must move but when looking at them they didn't want to budge and I was scarred of forcing it and breaking something.
Cheers for the tip on bracket, they should be all sorted. I just need to drill few more holes, I managed to snap a drill bit on Sunday....
#38 Captain Vimes
Captain Vimes
  • 2,755 posts
Posted 15 May 2013 - 09:19 PM
Check, check and check again before you drill the holes. Make sure you assemble it using the correct spacers and pull it into line otherwise the bracket might shift slightly when you go to nip it up and the holes will be in the wrong place...
#39 Sticky
Sticky
    iTB lover
  • 3,462 posts
Posted 15 May 2013 - 09:46 PM
:yeahthat:
#40 Crabash
Crabash
    Scared
  • 1,686 posts
I tightened mine before drilling the holes for the bracket for the above reason, you don't want the bracket trying to dictate where the rod end goes.
