Honda K24 Powered Speedster
984 replies to this topic
#981 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 05 August 2021 - 08:34 PM
Now I have come a little further with my handbrake cluster.
I need sort all wires to my gauges and then it will look better.
[img] https://i.imgur.com/4gRhzHG.jpg [/ mg]
Drawn a mount for my 3 meters instead of 2 that I had before
It did not turn out so well as the meter on the far left will not be visible when driving and there is a risk that it will touch the leg.
Then Mr. Mapper thought I should get a better broadband lambda.
So you I had to get a 4th gauge and it is very tight in our cars.
I think this can be good in the end.
A redesigned shiftlight bracket with space for gear indicator
The smaller rearview mirror with a suction plug  falls down a little now and then.
So a new bracket was printed so it can be mounted with double-sided adhesive tape instead. so now I can not get rid of it instead. :-)
This past weekend, a fairly important stronghold for this project emerged.
My aluminum bracket for my compressor. It feels significantly more robust than my 3d printed. :-)
Small test assembly
After a bit of fixing, it fit perfectly. :-)
Now I hope my 90mm long M6 screws will come soon. Had ordered 80mm but they only seem to have 5mm
in thread in alu which feels a bit meager. 90mm I have to cut a few mm.
But better that, get satisfied when I have to pull hard in Alu, it has happened too many times that it has become a thread pie.
More next time.
Regards, Per
#982 smiley
Posted 05 August 2021 - 09:16 PM
Any chance i can buy one from you?
I love my smol mirror, but sick and tired of buying 1-2 a year as the suction part does not last long.
#983 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 07 August 2021 - 06:59 AM
Yhea sure.
#984 Arno
Arno
  • 1,238 posts
Posted 09 August 2021 - 06:31 AM
If you are worried about stripping the thread, then it can be a good idea to put a helicoil or timesert in the bracket right from the start. That way you can tighten it to pretty much 'normal' values like in steel.
It reinforces the threads a lot. Quite common/normal on aerospace bits to always put a thread insert in alu parts for this reason.
#985 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 14 August 2021 - 08:32 PM
Yhea thats a good idea. But that wil be my second opttion, I dont want to take apart the supercharger.
Anyway, yesterday I got my longer screws, had to cut them off 5mm so now I have slightly more then 11mm thread depht
and supercharger is boted in place with screws tightened to 9Nm as Rotrex recommend.
If the threads ould give up and some time , I will use unicoil.
Thanks Arno.
Br, Per
    Bing (2)
