Lightweight Flywheel.
43 replies to this topic
#1 Korkey
Korkey
  • 227 posts
Posted 27 February 2013 - 04:39 PM
I have just purchased a lightweight flywheel for the VX turbo from TTV. The flywheel # 0643 to be used with the 7.25" clutch is now at the weight of only 2.6Kg. Previously sold at 3.6Kg. I have not found a lighter one, Standard unit is "about" 9.6Kg. This should have a noticable effect. The cost including p&p and VAT was £285.00p Should anyone be interested. Regards. Korkey.
#2 siztenboots
Posted 27 February 2013 - 04:44 PM
I had one of their supalite ones, but could not get the right sized clutch , so they exchanged it for me
#3 techieboy
Posted 27 February 2013 - 04:45 PM
Jesus. That's going to be hard work crawling along in traffic. :o
#4 JG
JG
  • 13,617 posts
Posted 27 February 2013 - 04:49 PM
There is a school of thought, going away from the topic slightly, that the best vx of all, is a standard NA with a lightened fly wheel and that's it. Maybe they aren't completely wrong. ;)
#5 vocky
Posted 27 February 2013 - 04:50 PM
There is a school of thought, going away from the topic slightly, that the best vx of all, is a standard NA with a 4.17 final drive fitted
#6 JG
JG
  • 13,617 posts
Posted 27 February 2013 - 04:53 PM
Ah, that's a different school of thought which is very very wrong :P
#7 Thealastair34
Thealastair34
  • 988 posts
Posted 27 February 2013 - 04:54 PM
enjoy getting that moving! i have a similar weight flywheel with a ap unsprung plate clutch and its horrific feels like there is 60bhp in letting the clutch out its that harsh!
#8 vocky
Posted 27 February 2013 - 04:55 PM
but then I am not really the best person to speak to about minor tweaks :lol:
#9 JG
JG
  • 13,617 posts
Posted 27 February 2013 - 04:56 PM
Mine is still standard thankfully :D
#10 techieboy
Posted 27 February 2013 - 05:06 PM
Talking of schools of thought and lightweight flywheels. What's the verdict on getting an OEM steel flywheel lightened (within suitable limits, whatever they are)? Good, bad or indifferent? I see some people say it's the best way as they're made stronger in the first place. Then I see others saying a lightweight flywheel machined from a billet of steel or aluminium is better. Then I see people saying if the flywheel has separate ring gear to never mix that with a different type of metal, due to differing thermal expansion. :unsure:
#11 turbobob
turbobob
    2/3rds of a Queen
  • 13,833 posts
    Photography
    CARS!!
    Travelling
Posted 27 February 2013 - 05:10 PM
I have the OEM flywheel machined to about 5kg (I think). And statically balanced. It's fine on mine. But I haven't been able to compare it to any other lightened flywheel.
#12 vocky
depends who you talk to, personally I think TTV make damn good lightened flywheels from billet steel and I would never fit a lightened factory flywheel or aluminium flywheel to my own car :huh:
#13 JG
JG
  • 13,617 posts
Posted 27 February 2013 - 05:11 PM
I must admit, the SC VX does really really need some weight shifting from the flywheel, so i'd be interested in the answer too.
#14 techieboy
Posted 27 February 2013 - 05:13 PM
I've got Courtenay's lightweight flywheel (4.2kg) in mine James. Definitely makes a difference. Usually good but I often curse it when pulling away in town and having to give it more revs than a standard one, to get some momentum. With the associated feeling that everyone is now looking at me as if I'm about to go wheelspinning off down the road.
Edited by techieboy, 27 February 2013 - 05:15 PM.
#15 Bumblebee
Bumblebee
  • 7,592 posts
Posted 27 February 2013 - 05:16 PM
I thought the ttv flywheel was the one Courtney's sell? If this isn't the case what the difference?
#16 vocky
Posted 27 February 2013 - 05:18 PM
depends which engine you are talking about, the 2.2 flywheel courtenay sell is two piece (flywheel and ring gear) and the TTV version is a single piece billet steel item
#17 vocky
Posted 27 February 2013 - 05:19 PM
that is because you also have the 'balancer delete', you should try the 'balancer delete' deleted version :happy:
#18 techieboy
Posted 27 February 2013 - 05:22 PM
WTF is that? :o
WIll it work on the Saab (no of course it won't, wrong bloody holes :beat:)
#19 vocky
Posted 27 February 2013 - 05:26 PM
WTF is that? :o
electric water pump, so no balancer chain :P
vectra B V6 or C20LET flywheel fits the saab B207 and F23 box set up ;)
#20 Nev
Posted 27 February 2013 - 05:42 PM
Hi Rich, how come you are going for a 7.5 inch clutch system? Lighening the rotating mass does make it a little pesky in traffic, but does also make the engine rev up considerably more snappily, which I am prretty sure you will prefer. Modern cars have heavier and heavier flywheels added to them fo emissions reaons, so the manufacturers can lower the idle RPM. I've heard that things like the Calibra V6 engine had masssive flywheel just to pass Californian emissions law (where the engine was used in some other US car), yet the same flywheel was realeased in Europe leading to a very lazy engine.
Edited by Nev, 27 February 2013 - 05:44 PM.
