So here's how to go about it.
To begin with, you'll need the following:
A pair of 3.5" speakers, I have personal experience with the following:
In-Phase 3.5" - approx. £25 for a pair, come with cabling and oversized grills which can be put down to go in the vent hole.
Rockford Fosgate 3.5" - approx. £50 - I bought this as I thought I had blown the above, it turns out it was a loose connection. No not come with cabling or grills
2 x Speaker Grill (if don't come with speakers) - get something larger than 3.5" as it will be cut down.
ISO 8 headunit terminals - whole unit is available here: http://www.polevolt....Connectors.html (you want the brown one)
Plywood
Tigerseal
Coping saw/drill with hole cutter
First thing is to add the two new wires for the front speakers to the ISO headunit connector - pin outs are detailed here: http://pinoutsguide....so_pinout.shtml There will be four gaps on the original wiring loom (for NA, I assume the turbo connects the optional front speakers here) in pins B3, 4, 5 and 6. Plug the new wires in following the layout detailed on the link. I found I had to cut off the whole connector and use the new one as the new terminals didn't fit into the old connector.
Run these cables to appoximately where you think the outer vents are.
Next take the ducting off the bottom of the dash (many crosshead screws) and cut the outer ducts off. Block the vents off with plywood cut to size. Bond with tigerseal and screw ducting back in place.
Next separate the two sections of the outer vent. This is a case of pushing the tabs holding the part that rotates in place. You want to keep the outer surround in place, as this will form part of the speaker grille.
Cut plywood disks with an inner cutout the same size as the speaker, and about a 1 inch diameter:
Cut into the foam around the outer vents so that the foam is level with the outer section of the vent. Bond the plywood in place.
Now mount the speakers to this.
All done!
