Posted 11 March 2013 - 03:52 PM
I have the front jacked up and on axle stands. The front suspension has been stripped. However I now need to jack up the rear and put it on stands so I can strip out the wishbones etc.
It currently has a stand on both front points (A)
If I use 2 jacks at point ( which points © or (D) should I use? I'm planning on removing the jacks once it is on stands if possible.
Then where is point © / (D) ? I presume from pics (D) is where the toe links join the subframe(?) It doesn't look like it would take the load too well, would this point hinder removing toe link or wishbones?
If point © is there a certain place along the shear panel it should go?
http://wiki.seloc.or...ile:Jacking.JPG
ps it's friggin cold and wet/snowy outside
Posted 11 March 2013 - 03:59 PM
Edited by smiley, 11 March 2013 - 04:04 PM.
Posted 11 March 2013 - 04:00 PM
and JG's project thread it looks like (D) is indeed where the toe link joins...
Posted 11 March 2013 - 04:02 PM
Posted 11 March 2013 - 04:03 PM
Posted 11 March 2013 - 04:04 PM
Edited by TazN, 11 March 2013 - 04:04 PM.
Posted 11 March 2013 - 04:13 PM
Posted 11 March 2013 - 04:36 PM
Posted 11 March 2013 - 04:37 PM
Didn't someone once make spacers so you could jack it with the undertray in place?
Another thing in my collection of bits I've never fitted or couldn't work out how.
Posted 11 March 2013 - 04:52 PM
I'm incredibly wet and cold now but it has no wheels left and hasn't fallen over. It has been jacked at the very front of the chassis beams as normal. A jack either side where the cross beam is. Then finally a stand where I think the 'tower' is, so just where the toe links join.
Pics to confirm where I mean and hopefully one of you more knowledgeable chaps will be able to say yay or nay and correct it to give a definitive answer with pics to go with it.
FRONT:
REAR:
Posted 11 March 2013 - 05:06 PM
Posted 11 March 2013 - 05:41 PM
Posted 11 March 2013 - 05:57 PM
Posted 11 March 2013 - 06:17 PM
Posted 22 December 2018 - 06:27 PM
This is my way,use 2 euro pallet.
How did you get it onto the pallet?
Can't think how this would be done without axle stands?
Posted 22 December 2018 - 09:56 PM
An old thread is coming alive.
Used only one portable jack and built up under the wheels.
The main reason for using pallets is that it makes it easy to move the car around, as we do not have so much space in the garage.
